Same here Spearfish99, i have had a weller gun for about 30 years now , been through a dozen tips and been abused not just for soldering but cutting foam as well.
I use it for soldering leads to motors rather than the digital tem controlled iron as i can get up to temp instantly and the tip size and power of the gun means it holds the heat better than the iron.
I normally use the iron when doing board work, for the little jobs, but each to their own.
daz
Oh and the gun makes easy work when soldering railings, you dont need a heat shunt.
