Author Topic: Lloydsman rudder setup help needed  (Read 1946 times)
malcf
« on: September 14, 2013, 07:46:52 pm »
If you have seen my build log i have incorporated the 5 rudder setup of the full size tug :embarrassed: ,having now done this i need advice on setting it up on my transmitter i have a 2.4 converted FF7 or a bog standard 2.4 5 channel tx to utilise, i would like to use the 3 rear rudders for forward propulsion only and the 2 rudders in front of the prop for reversing if possible,up till now i have it setup using the aileron stick for reverse rudders and rudder stick for normal position rudders i believe the real ship used just the 2 rudders for reversing and the 3 normal rudders just for forwards movement as far as i know %)  any help would be appreciated. :-))
Page created in 0.019 seconds with 22 queries.
