Author Topic: Fuse blows no load  (Read 9221 times)
Fuse blows no load
« on: September 23, 2013, 03:58:50 pm »
 Having got myself a rtr Pt 569    3x motors 1esc was surprised it had no fuses . Ran it  dry all working . Fitted a 40amp  fuse  cos thats whats in my Wiesel switched on the r/c and  plop fuse gone tried another same agin .  removed fuse  setup tried and all ok tried in the water for a few minutes nothing burnt out  .Though a disaster in other ways  to be discussed in another topic
Before I start taking things apart ie disconnect a motor or 2 major task for me
any other thoughts on  causes
grasshopper
    • A1 Hobbies Ltd.
Re: Fuse blows no load
« Reply #1 on: September 23, 2013, 06:42:15 pm »
Can you draw your circuit and where you fitted the fuse exactly?
Was it in the main line coming from the battery to the ESC or elsewhere?
« Reply #2 on: September 23, 2013, 07:19:37 pm »
Hi  in the main Positive from Batt to Esc
« Reply #3 on: September 23, 2013, 07:54:18 pm »
You must be taking over 40 amps. After that experience, I would have put a meter on the line to test the amps !!
Ken
« Reply #4 on: September 23, 2013, 08:02:51 pm »
Silly question time - it IS a 40A fuse?
« Reply #5 on: September 23, 2013, 08:15:32 pm »
Ken  my little meter only does 10amps
 Malcolm thats what it says on the packet
 Blade Type  Auto Fuses 40 Amp
Maybe thats why Graupner dont fit any
john44
« Reply #6 on: September 23, 2013, 08:18:30 pm »
what motors are they? can you get in to see? What battery and connectors are fitted
and what is the ESC rated at.
john
« Reply #7 on: September 23, 2013, 08:34:12 pm »
John  I have no info on anythings rating  all is accessible and they look as big as my graupner 600 The Battery is 8.4 nimh
there is a Pic here of one of the motors
http://www.modelboatmayhem.co.uk/forum/index.php/topic,44816.0.html
kmmbcwebmaster
    • Kingsmill MBC
« Reply #8 on: September 23, 2013, 09:16:07 pm »
If I'm not mistaken they look like there johnson 550 motors and under test I have had a draw of 20amp under load from one of these motors
just tugging along
« Reply #9 on: September 23, 2013, 10:20:10 pm »
I'm saying it blows   without any load ie no  motors turning and instant on power on
« Reply #10 on: September 23, 2013, 10:47:59 pm »
As grasshopper suggests......."Can you draw your circuit and where you fitted the fuse exactly?"....from you latest comment it sounds like a dead short wiring fault  :embarrassed:  ......
Possibly best to let a multi meter walk over each wire in the circuit/s......... Derek
« Reply #11 on: September 23, 2013, 11:07:43 pm »
Derek  its simply in the  positive lead from the battery to the esc a dead short ?  possibly but   I would expect  some sign of that running without the fuse .Only guessing. Multis are   only for checking batteries  for me  :}  not mastered owt else
NFMike
« Reply #12 on: September 23, 2013, 11:44:23 pm »
If the fuse is in the supply line from the battery how can you be running 'it' without the fuse in?
Is there a separate supply for the RX (and servos) and it is only those you are 'running'? In that case the esc is probably duff.
RAAArtyGunner
« Reply #13 on: September 23, 2013, 11:54:47 pm »
Can relate to your difficulty with multi meter etc, as I am not a lecky, or brilliant with wiring, as some others are on this forum, but your description does seem to indicate a dead short.
The suggestion to draw up the circuit, is a sensible starting point, as all else is pure guess work/speculation.
There are some really helpful "electrically" capable forum members and a drawing will help them help you. O0 O0 O0
Not to mention us others, who want to learn and do not want to fall into the same pitfalls.
Don't know if photo of the actual fuse setup may assist or not but you never know.
« Reply #14 on: September 23, 2013, 11:59:31 pm »
I am not suggesting checking current draw as you have previously indicated a 10 Amp limitation
Having said this....a compact multimeter will check for stray conductivity  ;D & I also have very limited knowledge of electrons & their mysterious black paths........ {-) Derek
old shrimper
« Reply #15 on: September 24, 2013, 01:21:03 am »
subscribe to this one
a photo would do in stead of a drawing
50 YEARS OF TOWING NETS
« Reply #16 on: September 24, 2013, 05:46:56 am »
The connectioin twixt batt and esc by tamiya I simply  fitted Tamiya extension and then fitted Fuse in th positive leg  To run without fuse  just remove extension . There is no seperate feed for the RX though have a feeling in me water   the R/c Saturn   might be a bit iffy . Will knock up a rough drawing   later today
 thanks for all other input
kmmbcwebmaster
    • Kingsmill MBC
« Reply #17 on: September 24, 2013, 06:32:46 am »
I understand that but was just advising that if solve this problem will have the same problem when underload with a 40amp fuse if they are johnson 550 motors.
plus from your description it sounds like who ever made this boat knew of this fault hence no inline fuses fitted
have you tried fitting inline fuses to each motor rather than from main feed ?
just tugging along
« Reply #18 on: September 24, 2013, 09:32:45 am »
Hi  just going through the early stages of  sussing out the cause / Inline fuses to  each motor  possible last reort . As for  whoever built Ha! this is  a Graupner  premium Line model RTR albeit I never got it  first  but doubt it had ever been used   or tinkered with. for some reason  I;m  a bit iffy about the RC it is a saturn and nowt much in their manual
old shrimper
« Reply #19 on: September 24, 2013, 09:38:44 am »
what happens if you disconnect 2 of the motors does it  still blow the fuse ?
imsinking
« Reply #20 on: September 24, 2013, 09:54:16 am »
Hmm , I'm just wondering if it's a 'momentary' feedback from the E S C ? as it's immediately after switching on . . .
In that case independent fuses to each motor would be the answer, fuses somewhere are a must ,weeds , garbage round the prop  etc, will possibly lead to a VIKING death for  the electronics or even the boat . . . we've had a few 'smokers' here , electronics mostly . . . it's not a pretty sight watching a grown man CRY  <:(
Bill
« Reply #21 on: September 24, 2013, 10:06:01 am »
Finding out if there is a dud motor is a good step, as is fusing each of the motors.  Not much point fusing a single motor, but when there are 3 of them on the same ESC....
If it blows the fuse with all motors disconnected, it indicates that something is amiss in the ESC causing a massive current drain during switch-on.
I can't see the RX making any difference, it's running off a 5 volt supply from somewhere and has been shown to work OK by the initial tests without the fuse.
« Reply #22 on: September 24, 2013, 10:25:06 am »
Ok here is the circuit  as such
« Reply #23 on: September 24, 2013, 10:27:42 am »
No Go area  soldered  i'm afraid
Off to   do a bit of Sailing now  Much less complicated :-)
old shrimper
« Reply #24 on: September 24, 2013, 10:31:33 am »
a pair of side cutters  will fix that
Page created in 0.024 seconds with 21 queries.
