Author Topic: model slipway trent props  (Read 3131 times)
luke1993
« on: September 29, 2013, 06:17:38 pm »
hi
running a model slipway trent fitted with 2x belt driven motors
2 x 6v hunter esc and 2 x 6v 4ah batteries it went very well today to scale speed
I know im running it only on 6v and the props I have are approx. 45mm 4 bladed brass
are these ok or will I get better performance from 3 bladed props
cant use any bigger batteries as esc state 6v dc
any help appreciated
mersey dave
Re: model slipway trent props
« Reply #1 on: September 29, 2013, 07:02:34 pm »
Hi mate, you could go for the bigger battery like the 6 volt 12ah this would give you up to 3 times more running time.
Best regards Dave.
« Reply #2 on: September 29, 2013, 07:12:19 pm »
you wouldn't get any better performance IMHO from running 3 blade props as against our 4 blade ones, but it does to an extent matter what profile the blades on the props are.......I have used semi clever scale props from prop shop on similar models in the past, as against the normal run of the mill scale props, and they work better.
luke1993
« Reply #3 on: September 29, 2013, 08:09:51 pm »
cheers its not the run time im happy with that the four bladed props I have don't seem to have so much pitch on them as the 3 blade probs
ive seen  I would like a bit more speed not  a lot just a little but stuck with 6v unless I change from the hunter 6v escs I have in there
cheers
stoney
« Reply #4 on: September 29, 2013, 09:03:35 pm »
 Hi Luke
 You say it went very well and to scale speed, my advice would be leave it as it is!
Paul
luke1993
« Reply #5 on: September 29, 2013, 09:09:13 pm »
best advice mate I think I will
 Hi Luke
Paul
rnli12
« Reply #6 on: September 30, 2013, 12:17:35 pm »
Hi Luke,
On mine I use 40mm 4 bladed Type A type and switched to type D but I do use Speed 600 eco motors on 9.6/8.4v x 2 nicd.
Conundrum...
But on the real Tamar they use 5 bladed and on the model 1/16th  45mm which is a tall order for the ECO 600 so may drop to 40/35mm unless anyone has used anything different?
kinmel
« Reply #7 on: September 30, 2013, 06:35:38 pm »
On my 1:16th TAMAR I used 4 blade 45mm props from propshop and they gave excellent performance with ECO600's.
luke1993
« Reply #8 on: October 06, 2013, 10:34:31 am »
sorted it got more speed one of the pully cogs was slipping  on the belt drive
a lot better now  :-))
Page created in 0.025 seconds with 21 queries.
