Author Topic: Robbe Najade  (Read 3950 times)
JamesD
Robbe Najade
« on: October 16, 2013, 05:34:48 pm »
Not sure whether i am in the right section.
Would like to convert my Najade to a brushless setup with esc and a couple of lipos,i am hoping someone on the forum as already done this,or can anyone tell me how to go about it,any help would be appreciated
James   :-))
Re: Robbe Najade
« Reply #1 on: October 16, 2013, 07:00:16 pm »
What motors do you currently have in it?
JamesD
Re: Robbe Najade
« Reply #2 on: October 16, 2013, 08:16:12 pm »
Hi Martin, its got the robbe stock motor 710/ ?
Re: Robbe Najade
« Reply #3 on: October 16, 2013, 08:35:56 pm »
looking at the spec of the motor you have on 12v it gives 15300 rpm so you will need a brushless motor with a KVA/volt of 1275/v this would give you the same revs as your set up now.
I obviously will stand corrected on this .
Skimmer Fan
Re: Robbe Najade
« Reply #4 on: October 16, 2013, 09:22:18 pm »
Do not do brushless yet so maybe some of the brushless guys could tell you about this motor I found in an advert for the Najade
The propulsion system is based on a ROXXY  3656-06 brushless motor driving the propeller direct via the propeller  shaft;
Skimmer Fan
Re: Robbe Najade
« Reply #5 on: October 16, 2013, 09:54:26 pm »
That has a slightly higher KVA than the original ........BUT would be spot on for the boat anyway,as  slightly more power is NOT a bad thing
Skimmer Fan
Re: Robbe Najade
« Reply #6 on: October 16, 2013, 09:59:19 pm »
That is the motor Robbe used when they went over to brushless.
Skimmer Fan
chris gillespie
Re: Robbe Najade
« Reply #7 on: October 17, 2013, 06:29:07 pm »
I have a roxxy in mine
It goes fantastic, i have it attached to a big Lipo, goes for ages
Original prop, i thought about putting a bigger brass one on...but i dont think it needs it
I know people have moaned about a right hand lean, with proper ballast there is none
JamesD
Re: Robbe Najade
« Reply #8 on: October 21, 2013, 04:09:11 pm »
Hi Martin, its got the robbe stock motor 710/ 12
Rottweiler
Re: Robbe Najade
« Reply #9 on: March 13, 2014, 12:30:32 pm »
A pal of mine has a Najade, with stock motors in , goes like stink,and the battery lasts for ages. I cant think why you would even want to change it?
Mick F
