Author Topic: Measuremants from a "Huco" insert  (Read 2483 times)
« on: October 27, 2013, 10:04:46 pm »
A quick question re huco couplings
The brass inserts have a hex shape to them.... anyone know the diameter across the flats?
Re: Measuremants from a "Huco" insert
« Reply #1 on: October 27, 2013, 10:22:06 pm »
11.25mm
« Reply #2 on: October 27, 2013, 10:24:20 pm »
e2v....these were Australian model shop purchased from a partioned large display case & all labelled Huco [all different bore sizing's in both metric & imperial]
The hex measures 0.443"AF.......it is not a machined hex size but clearly confirms that the hex bar was con cast......Derek
« Reply #3 on: October 27, 2013, 10:40:20 pm »
Perfect thanks chaps!
Knew I could count on you guys!
RAAArtyGunner
« Reply #4 on: October 27, 2013, 11:14:46 pm »
Just thinking out loud was the 'Zero' button pressed on the calipers :o :o %) %)
« Reply #5 on: October 27, 2013, 11:19:43 pm »
It was on mine and both results are within 0.01 inch.
« Reply #6 on: October 28, 2013, 01:24:40 am »
Guys.....it is certainly possible that both results are individually accurate O0
I have never looked at a Huco catalogue, but suspect the AF sizing would be nominated as whole number & certainly not toleranced  :D
Continuously cast brass or bronze sections are actually poured or cast through compressed carbon moulds which take into account the cooling & dimensional reduction that occurs
Typically for a hex section of less than 12.5mm AF,  one could expect less than 120 m of product feed before the mould was considering to producing unacceptably oversized material
As an apprentice, I sent 6 months in the copper & brass foundry & one of my daily tasks was drilling out the blank carbon upper mould inserts with the nominated number & diameter of holes on the set PCD to ensure the correct molten fluid flow through the lower mould assemblies  %)
For detailed measurement I don't use verniers with a TV set in the corner [but micrometers] , however vernier's with digital a image are far better for photography ....
 >>:-( afterall 0.443 x 25.4 = 11.2522....so the difference in component AF sizing is actually 0.0022 mm & that's a pretty small number ...... O0 Derek
Page created in 0.014 seconds with 16 queries.
