Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 248279 times)
missyd
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #50 on: December 22, 2015, 06:11:33 am »
Yes I will exactly do that. Maybe even 10x2mm planks and the a 0.8mm plywood cover over it ....
Danielle
« Reply #51 on: December 22, 2015, 09:35:55 am »
Your close frame style of build reminds me of the scantlings of wooden warships with their frames close together. Very attractive. It is a shame to cover them up!
missyd
« Reply #52 on: January 11, 2016, 04:28:20 pm »
After slicing the 3D model I drew all the sections .... best idea I had for ages! It makes drawing the hull very easy.
... and cut out the section out of 9mm plywood.
Danielle
« Reply #53 on: January 11, 2016, 09:40:08 pm »
Danielle...why do you use 'numeric/alfa' coding sequences for the frames?........23>23A>24>24A etc... when each appears to be of equal length spacing.....
It doesn't confuse me :o, are the builders original plans drawn & coded this way?
missyd
« Reply #54 on: January 12, 2016, 08:34:04 am »
Derek ... I had planned to have one frame every 40mm ... so I wrote the numbers on the original drawings. Then I changed my mind and went for 20mm space per frame and didn't want to delete the numbers on the drawing .... therefore the frames are numbered -1, 0, 0A, 1, 1A, 2 etc ......
Danielle
Unsinkable 2
« Reply #55 on: January 12, 2016, 08:08:25 pm »
When I built 'Lena' I ended up doing something similar as also didn't want to alter my drawing. In the aircraft industry they do the same when they build a longer version of the same aircraft.
Looking good missy but after seeing how good the last one was I've come to expect quality from you. Well done, I'm following with interest. U2
It'll look better when it's finished!
missyd
« Reply #56 on: January 21, 2016, 01:10:35 pm »
Thanks a lot  :-))
Some more work ist done .... in a few days the hull will be ready for planking.
Hull is sanded ...
As I forget totally that I had to have space for the motor I had to make space for it ...
And the second half of the hull is getting together ....
This angle is very important ....
More section are beeing glued together ...
These are the last sections ....
Danielle
missyd
« Reply #57 on: January 22, 2016, 05:24:39 pm »
Finished glueing the sections together!
I put the hull together with the help of some clamps .... hope you like it.
Danielle
Mark T
« Reply #58 on: January 22, 2016, 05:45:50 pm »
Danielle that looks epic!!!  Trouble is now you are going to have to make it look as good inside as out to show off your carpentry skills.  Keep the pics coming!
Big Ada
« Reply #59 on: January 22, 2016, 06:54:11 pm »
Now you are teasing us Danielle, with that Large Mechanical Shovel in the back ground, is that Scratch built?.
Len.
jarvo
  • Etherow model boat club
« Reply #60 on: January 22, 2016, 08:26:21 pm »
Danielle, your framing is superb, both fit and shape, almost a pity to plank the hull.
Mark
Tugs are for pulling
missyd
« Reply #61 on: January 23, 2016, 06:35:14 am »
Thanks a lot to all of you!!! I'll do my best to keep you happy .... ok2
The large shovel in the background is a Lego Technic Set .... assembled by my wife Anita. :kiss:
Danielle
missyd
« Reply #62 on: January 31, 2016, 07:44:04 pm »
Some more work done .... I let the pics speak for themselves .... any question will be answered asap ....
Danielle
missyd
« Reply #63 on: February 05, 2016, 04:18:00 pm »
As usual some more work done ....  ok2
Danielle
missyd
« Reply #64 on: February 05, 2016, 04:19:56 pm »
... and here are the RAL numbers for the colors.
I need the RAL number for the antivegetive paint .... what can I use for it?
Danielle
Unsinkable 2
« Reply #65 on: February 05, 2016, 08:54:13 pm »
Danielle, I'm no expert but is there any chance that 1 and 2 in the first pic and A and B in the second are actually the same colours but just affected by one surface being in the shade and therefore looking darker?
1 and 2 do look a little different but A and B look quite similar to the untrained eye! ;)
Just a thought........it's looking awesome by the way,     U2
« Reply #66 on: February 05, 2016, 11:09:52 pm »
missyd.......I tend to agree with U2.....& think the dockyard would have ordered 20 litre drums of blue, 20 litre drums of white & 20 litre drums of rust coloured anti fouling??
A bit difficult to take the ship to the paint shop, but that fisherman's washing would be an easy match %)...... Derek
missyd
« Reply #67 on: February 06, 2016, 12:36:23 pm »
1, 2 & A are the same color dark blue. Affected by sunlight they look like 3 different blues. B is a light blue. This was confirmed by the builder of the ship.
Anti fouling color changes its color as soon as it gets wet ....   :-))
Danielle
missyd
« Reply #68 on: February 11, 2016, 08:55:55 pm »
Some more work done .... hope you like it.
Danielle
jarvo
« Reply #69 on: February 11, 2016, 09:15:32 pm »
Danielle, The planking is as usual superb, with the heavy ply ribs, the strenght of the hull will be phenominal, please dont fall into the underpower trap as you did on Cornilia, what glue have you used on the planking???
Mark
missyd
« Reply #70 on: February 12, 2016, 08:29:52 am »
Thanks a lot Mark. Planking is 10x3 pine. Glued to the ribs by normal wood glue ... but the fast binds in 20 minutes version .... ok2
Danielle
missyd
« Reply #71 on: March 08, 2016, 08:30:22 pm »
More work done ....
Test if everything fits together ....
... and glued together.
Some filler added .... and later sanded ----> work as usual....  ok2
Danielle
« Reply #72 on: March 08, 2016, 08:41:31 pm »
Looking good Danielle.
Unsinkable 2
« Reply #73 on: March 25, 2016, 08:35:22 pm »
Coming on great....... I really like following your builds. Keep up the good work.   U2
missyd
« Reply #74 on: March 26, 2016, 05:52:55 pm »
Tanks a lot to you all!!!
More work done ....  ok2
I am fitting a keel made of 2x7.5x2.5mm brass ... looks nice and gives some more weight at the bottom.
Danielle
Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... 28   Go Up
Page created in 0.021 seconds with 22 queries.
