Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 227222 times)
missyd
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #100 on: May 25, 2016, 02:22:00 pm »
HI Danielle, are you on a deadline to deliver this model????  you are moving forwards very quickly compared to CM
Mark
Thanks a lot.
No I do not have a deadline .... I am jobless for the second time this year ... plenty of time each day to work on the model!
And I have another nice trawler waiting to be built ....  ok2
Danielle
jarvo
  • Etherow model boat club
« Reply #101 on: May 25, 2016, 04:46:12 pm »
Sorry to hear about your job, hope that is cured quickly, but you are moving along with the build, BRILLIANT
Mark
Tugs are for pulling
missyd
« Reply #102 on: May 26, 2016, 04:49:33 am »
Mark
Thanks a lot Mark. I will find another job soon ... not the first time I have to look for another job.  ok2
Actually as I built the Cornela Marie I was 4 months at home without a job and built most parts of the CM then.
Danielle
missyd
« Reply #103 on: May 26, 2016, 05:55:48 pm »
Little parts to hold the side panels on place ...
Another section was shortened ....
doubling the size of the part that holds the rudder ....
Danielle
missyd
« Reply #104 on: May 27, 2016, 08:02:51 pm »
To keep the side panels straight I used 2x4mm pine ...
Side panel glued on hull
Raedy to be soldered ....
Danielle
missyd
« Reply #105 on: May 28, 2016, 08:22:40 pm »
Soldering done ...
Danielle
« Reply #106 on: May 28, 2016, 09:53:06 pm »
She's coming on nice and steady - good work so far. :-))
missyd
« Reply #107 on: May 30, 2016, 04:49:59 pm »
Thanks a lot Ray!  :-))
Some more work done ...
Bow truster ....
Danielle
« Reply #108 on: May 30, 2016, 09:31:18 pm »
Having crushed my kort nozzle last weekend driving home I am inspired by your reinforcement of the ruddeg area to use your approach when doing the repair work.
Lovely work as usual and I echo previous comenst and hope you find another job shortly.
missyd
« Reply #109 on: May 31, 2016, 06:03:34 pm »
Thanks a lot! Had an interview today for a job .... lets see if its something for me.
Opened up the hole for the bow truster.
Not finished yet ....
Not shure if I should use a working bow truster or not ... there is very little space for it ....
Danielle
« Reply #110 on: May 31, 2016, 09:06:38 pm »
Hm. As you have made the holes you may as well fit one. The hull is good and stout and you can always reinforce the area surrounding the thruster.
Good luck with getting the job!
missyd
« Reply #111 on: June 01, 2016, 08:11:43 pm »
 :-)) Thank you very much ...
I opened up the section where the bow truster will be .... I may use a waterpump with two pipes at an 90° angle in the bowtube instead of a propeller driven bow truster. Pump aspires water at the right and blowing it to the left and vice versa .... I'll go to my model shop tomorrow to see what I can buy ...
Danielle
hama
« Reply #112 on: June 01, 2016, 09:46:18 pm »
Interesting choice, please tell us how it goes. I've had similar thoughts regarding bow thrusters and I know many have done this. Easier to place and replace when needed. My concern is only to find the correct pump. I've had my eyes on a "Kavan fuel pump", made for airplane modellers and works both ways. I have a pump from Conrad that I intend to test in a boat eventually.
Very nice build by the way!
Hama
jarvo
« Reply #113 on: June 01, 2016, 10:14:01 pm »
Another possibility is to use a full size bilge pump, they do come in small sizes, a lot are shown on ebay, a lot cheaper than model bow thrusters, just make sure that the motor and impellers can run in reverse.
Mark
« Reply #114 on: June 01, 2016, 10:18:31 pm »
As part of your research and prep for this plan. Have a look at how Bob K modified his pump system after Polyphemus suffered pipe/joint failure last year so that you can make your system as watertight as possible to prevent filling your hull with water at an impressive but annoying rate.
It is in the Warships section and was updated recently so should be on the first page.
missyd
« Reply #115 on: June 02, 2016, 07:22:26 pm »
I had a good look at the topic with the pump .... as the Cornelia Marie had a waterpump in the beginning I am quiet used to make everything watertight.
Just bought this pump ---> http://www.kavanrc.com/cgi-bin/dpsmart.exe/GMainMenuFV6.html?E+Kav
... and many other things for building the boat.
Danielle
« Reply #116 on: June 02, 2016, 09:05:05 pm »
Isn't it great when you can have a splurge on your interest! I am glad that you have the pump and its systems sorted and wish you well with instaling it all.
missyd
« Reply #117 on: June 03, 2016, 04:01:19 pm »
Biggest part the tube is ready ... its a 1" brass pipe ... we have a shop nearby who sells such things... it was my wifes idea!
Danielle
« Reply #118 on: June 03, 2016, 08:53:41 pm »
No little toys for you Danielle - this looks like it is going to be a mean machine. :-)
missyd
« Reply #119 on: June 04, 2016, 05:41:35 am »
Yessss! I build my model sturdy and as heavy as possible! No flimsy plastic hull! Just like the real thing!  ok2
Danielle
Big Ada
« Reply #120 on: June 04, 2016, 06:09:03 pm »
Link goes to a Site with Planes also not in English.
Len.
missyd
« Reply #121 on: June 04, 2016, 06:17:09 pm »
Can't link it directly .... it is a fuel pump intended for RC-planes ... one of the only that work in both directions ....
Danielle
missyd
« Reply #122 on: June 06, 2016, 04:47:53 pm »
Nearly finished ... I still have to solder the protection bars on the openings ...
Danielle
jarvo
« Reply #123 on: June 06, 2016, 05:52:04 pm »
That looks great, will you have enough water flow to be effective? I assume it will suck from 1 side and blow to the other
Mark
missyd
« Reply #124 on: June 06, 2016, 07:35:21 pm »
Mark
Thanks a lot Mark. Yes one in the other side out and vice versa. The pump has 1.8L/min ... there is no stronger pump on the RC market ... I'll try it out in the next few days before I fix it into the hull.
Danielle
Pages: 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 ... 28   Go Up
Page created in 0.021 seconds with 22 queries.
