Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 28   Go Down
Author Topic: M/P Nuova Loredana Italian Fishtrawler  (Read 227709 times)
Re: M/P Nuova Loredana Italian Fishtrawler
« Reply #125 on: June 07, 2016, 11:16:01 am »
1.8 L/minute is not a great flow Danielle.....but for assistance with docking will be OK :-))
Just be sure to fully epoxy or solder the internal central dividing intermediate isolation disk between the suction & delivery sides  %)
missyd
« Reply #126 on: June 07, 2016, 08:14:04 pm »
.... there is no Divider between the tubes ... impossible to fit one ... left tube is 90° and goes to the right near the opening and vice versa .... the 90° tubes (like an elbow) are crossed in the middle ....
Danielle
cos918
« Reply #127 on: June 07, 2016, 10:04:28 pm »
Hi Danielle
With a boat has big as yours and the weight . You might fine you are not moving enough water to turn the boat .  Have a look in non modelling areas. You can get Caravan fresh water pump 12v that will shift 5L per min.
Your in take might all so be restrictive . One option might be X2 pumps . they suck water in from under the flat of the hull near the keel and exit via the bow thruster  .X1 for port X1 for starboard .
http://www.ebay.co.uk/itm/like/361554236766?lpid=122&chn=ps&googleloc=1006976&poi=&campaignid=207297426&device=c&adgroupid=13585920426&rlsatarget=aud-133395220626%3Apla-156022122546&adtype=pla&crdt=0
https://plus.google.com/photos/105202506859524458881/albums/5117538442090596849?banner=pwa
missyd
« Reply #128 on: June 08, 2016, 06:18:15 am »
Thanks a lot for all informations!
OK folks ... after some thinking I will redo everything and build another bow truster ....
Danielle
hama
« Reply #129 on: June 08, 2016, 06:57:27 pm »
Could you please test the pump in a watercontainer and check performance?
Im quite interested myself!
All the best.
Hama
missyd
« Reply #130 on: June 09, 2016, 10:17:53 am »
I did test the pump today with 12V ... I think it should be enough to help with "parking in" the model ... BUT in windy or situations with a lot of water current it won't help much ... can tell it only after the hull is in the water...
Short video: https://youtu.be/Urg6QWqV_XI
Danielle
missyd
« Reply #131 on: June 09, 2016, 04:29:28 pm »
Finished the bow truster today ...
And put an ABS pipe over the end of the propshaft.
Danielle
jarvo
  • Etherow model boat club
« Reply #132 on: June 09, 2016, 04:42:23 pm »
Wow that looks a mean piece of brass work, hope its got the power you need for a heavy hull
Tugs are for pulling
missyd
« Reply #133 on: June 09, 2016, 05:01:02 pm »
I think the pump may be a little bit weak but the original has a bow truster and I wanted to hae one too without paying a fortune for one you can buy in a model shop ...
Danielle
jarvo
« Reply #134 on: June 09, 2016, 05:04:45 pm »
Have you looked on ebay for a bilge pump, some of the guys over here have used small ones to great effect and they are a lot less than model type pumps, the hull is way big enough for it to fit
Big Ada
« Reply #135 on: June 09, 2016, 06:20:11 pm »
Bilge Pumps seem to all be submersed in water, do they do one with in and out hose connections ?.
jarvo
« Reply #136 on: June 09, 2016, 08:23:44 pm »
Yes they are if you get the self priming type
« Reply #137 on: June 09, 2016, 08:36:29 pm »
I like seeing a good bit of brass work on a model, it adds something good and traditional!
missyd
« Reply #138 on: June 09, 2016, 08:38:27 pm »
Thanks a lot to you all ... I leave it as it is ... the model can't cost much as I have a limited Budget of 800 Euros including the RC.
Danielle
hama
« Reply #139 on: June 09, 2016, 08:50:39 pm »
Hello!
Thanks for the video! I'm definitely gonna try a similar solution. One benefit is that it's a lot easier to replace the motor(pump) if it breaks or is too weak.
Hama
missyd
« Reply #140 on: June 13, 2016, 06:21:11 pm »
Finished the bow truster ....
Added openings at the back ....
Glued the inner part of the back on the hull ...
Danielle
missyd
« Reply #141 on: June 14, 2016, 09:34:24 pm »
More work done ... reinforcement of other parts ... the arch will be fixed on the most forward part ...
Danielle
jarvo
« Reply #142 on: June 14, 2016, 10:12:41 pm »
That hull and superstructure will never be described as flimsy, real quality materials being used.
Mark
missyd
« Reply #143 on: June 15, 2016, 05:46:21 am »
Mark
You're right ... I always use 9 and 6mm plywood of the highest grade. It can be cut, drilled and milled without problems ... and is sturdy and heavy.
Danielle
missyd
« Reply #144 on: June 15, 2016, 08:04:47 pm »
Some more work done ...
Danielle
« Reply #145 on: June 15, 2016, 11:05:21 pm »
It reminds me more and more of a real sized wooden man o' war with the ship builders use of several layers of timber including unusual shaped pieces. Final finish aside. the wood work on this model is very attractive.
jarvo
« Reply #146 on: June 16, 2016, 12:23:23 pm »
Talking of weight, the CM sail very well in choppy water, this should be just as good
Mark
missyd
« Reply #147 on: June 16, 2016, 04:48:50 pm »
I hope she will be fine in the water ..... never buit such a hull before. The CMs bathtub shape had to float well. I will put er into water in a few days!
More work done ...
Wasn't happy with the thickness so I added anotther 4mm to the back.
And to end the day with something new I started to place tha anchors ...
Danielle
missyd
« Reply #148 on: June 17, 2016, 11:10:54 am »
Finished the back ... some details missing but I will add them later...
Danielle
« Reply #149 on: June 17, 2016, 08:17:24 pm »
Quality work as per usual Danielle.
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 28   Go Up
