Author Topic: what exactly is this please.  (Read 4249 times)
Leovilla
« on: December 19, 2013, 04:08:56 pm »
My maternal grandfather (died 1953) was a merchant navy Captain. My mother (died 2011) let me have what you see just before she died informing me it was my grandfathers from his days at sea.
When looking through the eye piece at any light it shows red.
Does anyone know precisely what this instrument is. I intend to keep it for my grandson and it would be nice to be able to explain to him what his great great grandfather used it for.
furball
Re: what exactly is this please.
« Reply #1 on: December 19, 2013, 05:09:30 pm »
Some sort of surveying instrument?
It looks like you could take a bearing through the eyepiece against the wire. I can't think why there would be a red filter in there though, unless it was to cut down glare.
Lance
« Reply #2 on: December 19, 2013, 05:18:15 pm »
A range finder for keeping distance in convoys.
The lateral bars are a bit of a mystery though.
GAZOU
« Reply #3 on: December 19, 2013, 05:49:43 pm »
this is a very powerful device
we put it on the ass of a chicken
and see if there is an egg
In Australia they have the same
but larger for ostriches
Now the X-rays are used     O0
BrianB6
« Reply #4 on: December 19, 2013, 09:33:51 pm »
Sorry to correct you Gazou.
We only have them for Emus down here.   It's the South Africans that use them for Ostriches.
« Reply #5 on: December 19, 2013, 09:58:51 pm »
 %)....no ...not for egg sizing.... :embarrassed:......
But really is a "Mast Aligner"......similar in concept to a theodolite   %) ....but used principally for checking the vertical alignment of a mast  {-) .....Derek
tobyker
« Reply #6 on: December 20, 2013, 12:24:48 am »
It looks as if you could lay it on top of a large binnacle compass to take a bearing. Maybe the red filter is to retain night vision if you are taking a bearing on a lighthouse or masthead light?
furball
« Reply #7 on: December 20, 2013, 12:57:48 am »
Google 'circumferentor', and have a look at the images, it looks like it could be part of one of those.
Lance
w3bby
« Reply #8 on: December 20, 2013, 08:25:03 am »
I would have a guess at an "alidade" to be used in conjunction with a ships compass for taking bearings. You will find similar on  a prismatic compass.
TailUK
« Reply #9 on: December 20, 2013, 09:26:34 am »
It's a Relative Bearing Indicator or Pelorus.  Used in conjunction with a compass, it's used to check the bearings to fixed objects or other vessels.  The red lens is for night use as the illumination could spoil an officer's night vision unless viewed through a red filter.
« Reply #10 on: December 20, 2013, 09:33:31 am »
methinks perhaps the red filter is to reduce the glare from the boiler fires whilst measuring ''The Golden Rivet''  :}
MikeK
  • Utter Bloody Chaos !!
« Reply #11 on: December 20, 2013, 09:37:56 am »
Beat me by 9 minutes TailUK ! It is indeed a Pelorus used for bearings. The 'arms' fit neatly on the compass/repeater top without any play enabling it to be swivelled around the top
TailUK
« Reply #12 on: December 20, 2013, 09:43:17 am »
Sorry Mike!  Leovilla's example should be made in Brass, another non-ferrous metal or have a hardwood frame to prevent the device from interfering with the compass.  Another name for the pelorus was "dumb compass"
Leovilla
« Reply #13 on: December 20, 2013, 09:46:45 am »
Thanks gents. It is indeed made of brass. It has its hardwood box which sadly is in a bit of a state.
 Any idea what age it may be and when they were first used..
TailUK
« Reply #14 on: December 20, 2013, 11:11:20 am »
The name Pelorus dates back to Hannibal's Navigator in 200BC.  The instrument was named for him.  The earliest reference I've found fter a couple of minutes digging was to 1912.  Titanic was fitted with 2 Peloruses (Pelori?) One on each bridge wing.  I should imagine that such a navigational instrument goes back a lot further possibly hundreds of years.
Yours looks vaguely military and may have found it's way onto a merchantship as the personal property of an officer or as military surplus.  The night vision lens also suggests military use.
From a little experience with instruments I'd hazard a guess that this is 1930's to 1940's, give or take a little.
GAZOU
« Reply #15 on: December 20, 2013, 11:58:49 am »
it was the same ?
Jerry C
« Reply #16 on: December 20, 2013, 12:39:59 pm »
It's an azimuth mirror used with a compass which has a center pivot point bonded to the top glass. It may also be used with a pelorus. A pelorus is similar to a compass but has no direction keeping properties. It is used to measure relative bearings which when applied to the ships head give compass bearings.
Jerry.
MikeK
« Reply #17 on: December 20, 2013, 01:08:11 pm »
Good old Hannibal, sailed with him when he was apprentice. Not that that has any bearing on the subject !
Geddit ?
Merry Xmas one and all
