Pages: 1 2 3 4 5 6 7 8 9 10 [11]   Go Down
Author Topic: Re: Diving support vessel Well Enhancer scale 1:75 - v2  (Read 137048 times)
tweety777
  • Very passionate about ships
« Reply #250 on: August 19, 2025, 04:31:31 pm »
Hello all,
Considering the extreme difficulty steering the ship on a desired course I started trying to cannibalise old servo's to get some proper control over the steering with which I can steer the course I want her to sail. Unfortunately I damaged the servo electronics so I ended up buying new servo's. Today I managed to make them work with new gears and a plate to mount them on. In the video below I'm testing the new servo's:
https://www.youtube.com/watch?v=Y2qK5vOKexQ
Greetings Josse
tweety777
« Reply #251 on: August 28, 2025, 08:06:40 pm »
Hello all,
In my previous post I showed a video of the new servo control at work, here is a photo of the setup. At this moment I'm considering moving to continuous rotation servo's with AS5600 sensors for feedback for moving the thrusters because these are so much smaller then the steering motors which I've now replaced. I'm also considering this option for controlling the cranes, most of all the main crane because that might well require too much power to turn for the small reduction gear motors I currently have connected for that purpose.
The time has now come to start working on the new hull, here I'm drawing out the frames so I can get my saw to work. I decided to make the mold in 4 parts and place wooden plates in between the 4 parts beforehand as if I've cut the hull in 4 pieces so I don't need to wait for 3 days until the epoxy on the first part has properly cured and then risk slightly misaligning the wood for the second mold. I will now have 2 perfectly straight and 100% fitting connection lines between the molds. The flip side of this decision is the especially the front most part of the bow risks not being as nicely round at the centreline, which I will compensate for by adding 2 full layers of 200gr fibreglass, 5cm wide along the merge between the 2 molds so I have room to make it perfect afterwards without risking making it a weakness. I might well do the same in the critical areas in the stern as well.
On this plank I will construct the hull, I started drawing lines where the frames will go, taking into account the 4cm thick styrofoam which will fill the gaps between the frames.
All the frames have now been cut out and I've glued blocks of wood onto the lines to provide some guidance for placing the frames. Here I've already made 2 mistakes which I will point out below the corresponding pictures.
The wooden plank I will use to shape the styrofoam and after that to check the shape.
Here I corrected the first mistake at the point where the mistakes where the most critical. I raised the hull by 60 1:1 cm's, so 8mm on my scale so having the wooden framing extend ahead of the bow with much more then 8mm would cause considerable problems in shaping the bulwark properly. The same mistake also extended to the stern though there the bulwark remains a full deck lower so it doesn't cause any issues there other then the slight inconvenience of having this odd shape in 1 mold so it will not align is well as I'd like it to be.
The second mistake I corrected while it was still quite easy. It's the wooden blocks behind the rear most frame which is the very stern of the ship. Leaving these wooden blocks in place would have made releasing the mold very difficult indeed.
I started filling up between the frames with styrofoam, though I did get a bit further then shown here by now.
Considering the softness of the foam I will apply a layer of GRP before making the molds to ensure a good quality mold.
Greetings Josse
tweety777
Re: Diving support vessel Well Enhancer scale 1:75 - v3
« Reply #252 on: September 03, 2025, 07:21:09 pm »
Hello all,
I put my mind on the transmitter for a bit, it needs to be ready in half a year to control the final version of this model. The wiring between the Pi and the first set of electronics had become quite a mess so I took it out and replaced it with new, proper wiring.
The power here was attached using a whole lot of single connectors which I have now replaced by 2 large connectors to make sure all connections remain fixed.
Since it became very clear that the only proper means of steering this ship is through heading control over the azimuths I started removing the joysticks and now not needed electronics and try to see how the new components will fit, both physically and in terms of wiring.
I put 2 USB sockets in the side of the transmitter, the top 1 (left in the photo) can be used for connecting a keyboard while the other one is the charging port to which I may add a charging LED in the future. This week I decided to drop the 27A powerbank in favour of a 26 gram weighing 9V battery with 28A of power while costing far less then the powerbank used to cost. I will include some miscellaneous stuff to mount the battery properly right underneath the charging port. The PCB atop the Pi handling the power and cooling for the Pi can easily handle the 9V, converting it to 5V for the Pi and other devices through 2 secondary 5V connectors so I will also power the remaining parts through these port.
The power sensor (measuring voltage and amperage) has been connected to keep track of battery status along with the new on/ off switch.
All in all the wiring got quite a bit tidier then it was.
Greetings Josse
tweety777
« Reply #253 on: September 18, 2025, 10:30:00 pm »
Hello all,
I got my first birthday gift in the shape of an Airfix giftset 1:72 Westland Sea King. This will be put on the helodeck when the flying helo is not around. Since this ship is not build to sail with her own helicopter I will make the model in a ready to start configuration, with instruments and interior lid up, but engines turned off to save fuel.
The nice thing about hanging around with photographers is that tends to be 1 available when one decides to go for a sea trial to check the latest adjustments in the steering.
The sea trial was a great success! Up to the point where the gears fell off of the servo's (because why bother screwing them on the servo...), the battery went pretty much flat in about an hour and eventually even pulling an entire water plant into the propeller. Sailing went great with really good manoeuvrability and proper control over the course which used to be a great issue. The bow thrusters turned out to be useful even at some speed and the proved powerful enough to move the large superstructure even in the wind conditions today.
https://www.youtube.com/watch?v=f8--mzrQIf4
With the sea trial a good success I mastered the courage to make the 2 remaining joysticks fit properly in the add on for the transmitter.
I found the courage to continue with the transmitter also because I sent the files for the new throttles, along with the new thrusters, to a friend who will print these parts in resin. I upgraded the throttles will designing the new version by adding backlighting so I can see in the dark what I'm doing. While typing this I realise this might also be a good idea to do with the rudder indicators and perhaps I can even mount some LED's such that they provide some lighting on the joysticks.
This is an impressive row of controls. The middle stick will control the retractable bow thruster.
The base plate for the throttles will be too big to fit through the existing holes while also leaving room for the push button. I will add a plate on the inside as well to make sure the throttle is properly aligned.
The potentiometer will be push against the back wall of the throttle quadrant en fixed in place by a small plate.
This is the test version printed with my FDM printer. This is a poor type of printer for making proper angle markings like I designed here. The silver cylinder is a slip ring to fully eliminate restrictions on the amount of rotations I can make. The LED which will provide the backlighting is also visible here.
Greetings Josse
tweety777
« Reply #254 on: September 28, 2025, 08:19:31 pm »
Hello all,
Today I sailed all day with my modelling club, ran a full battery flat because I hardly took a break from sailing because I was enjoying myself so much.
The drone itself is hard to see, it's rotorwash is clear though. Would I've had the helodeck ready it would've basically been landing on the deck here.
https://youtu.be/EHB85an_Nhc
https://youtu.be/0ucsQX1cdxg
https://youtu.be/wIpAAF3Hfp4
https://youtu.be/F7uZRC7CF6c
Greetings Josse
tweety777
« Reply #255 on: October 25, 2025, 10:35:18 pm »
Hello all,
The new throttle levers have arrived. I do need to modify the lever so it will fit on the shaft of the potmeter which turned out not to work quite so well due to printing difficulties.
This is a big step towards completing the transmitter, though there is still a lot of programming to do.
There will be a new, deeper version of the extension because this is quite impractical and there is not much room for mounting the potmeter for raising and lowering the retractable bow thruster. In the new version the electronics will be mounted vertical to leave as much room as possible.
The new thrusters have arrived as well. The smaller set is for a club member who is building a firefighting vessel.
The new thrusters will most likely be much more quiet then the Graupner units I've had for pretty much 17 years now. The propeller is a lot better as well.
Considering the possibility of night sailing with the modelling club I decided to add some lighting so I can see the model in the dark. All lights are placed and connected temporarily and can easily be removed and the lights which are fixed in place are fixed on place which are yet to be replaced.
Greetings Josse
tweety777
« Reply #256 on: November 11, 2025, 10:18:54 pm »
Hello all,
Filling the hull is now fully on it's way.
After having optimised the design I printed the new bowthrusters so I can now start assembling them. I do need to shorten the drive shafts before I can fully assemble the bowthrusters.
After an attempt with a 9V battery which is indicated to have 28000mAh, but in reality turns out to be a much more reasonable 280 mAh which is far to little for my power hungry transmitter I now upgraded to a proper battery being a 14,8V 10000mAh which should be enough for running the transmitter the entire day. There will be a battery status display which is yet to be delivered. The new battery is now fully attached (apart from the status display) and has proven to be more then capable of powering the entire transmitter and the problems with the screen have vanished because it now gets enough power.
The new addition has been designed and printed. The entire transmitter has become quite a large unit, zo most likely I'll be putting it on a camping table for ease of transport wherever possible and have the neck strap as back-up for where the camping table can't stand, in my neighbourhood the waters have fairly steep patches of grass making the closest place for the camping table the middle of the road.
The colours on the buttons is the wrong way around here (it's been corrected by now) but the general idea will be clear. 1 of the major reasons for making the new addition was to create room for the potentiometer, which has now been placed.
Most of the electronics are now put in place, all that remains to be done is connect the potentiometer and the LED's for the backlighting.
The bigger addition does leave a lot of room for upgrades should the need arise.
Greetings Josse
« Reply #257 on: November 12, 2025, 10:59:47 am »
Is this a new Hull Josse ?
tweety777
« Reply #258 on: November 18, 2025, 03:36:31 pm »
Hi Martin,
This indeed is a new hull. I ran into to many problems with fitting electronics and wiring properly, bilge keels breaking off, forward bulwark being to low and the list goes on and on. Add to that list my intent to have this project as a prototype for all to come, where all to come will be made with a GRP hull, and it became quite clear that building a new hull would be the easy solution for all the problems.
Hello all,
Behind the scenes I'm working on assembling the thrusters and bowthrusters, this is not yet going fully according to plan, quite possibly due to the shafts being just shy of the needed 4mm that a proper propshaft would be. In any case, moving the drive shaft by hand doesn't yet result in a constantly rotating propeller.
Since the superstructure will not be replaced but rather be moved to the new hull when the time comes I can continue the work on the superstructure so I started adding the platforms.
In this photo it would appear the upper deck is not 100% flat, I'll be checking that.
Starts to look more and more like a ship now.
The indicators for the throttles have been glued in place, now I only need to add the cut-outs for the locking system on the throttles so I can start to mount them permanently.
Considering the I2C cable from the Pi often comes loose I permanently placed the multiplexer PCB and put a drop of hot glue on the pesky connector for good measure. Using hot glue makes it easy enough to remove the connector if need be but make sure it won't happen without human interference.
Quite an important step is being able to connect the main part of the transmitter to the addition so after having corrected the holes I now glued the connectors (each with a strong magnet besides it) in place. Originally I had used a a mold to determine the position of the holes but I placed that to the wrong reference point.
Greetings Josse
tweety777
« Reply #259 on: November 19, 2025, 03:37:06 pm »
Hello all,
The 2 transmitter parts can now be connected to each other! Off course in such a way that they're easily taken apart again as well so I can later add the addition for whatever new project I'll start in the future.
The connector has been glued in place and the power for the servo's in the addition have been added.
Though I had been careful while gluing the connector in place, it doesn't fit anymore when trying to reconnect it. I'll need to investigate this because I have have these same connectors in use for Well Enhancer.
The holes for the throttles have been modified so the throttles now fit fully in place.
The USB port on the side has been replaced by a double USB port so I can mount the WiFi repeater in there and still have the keyboard dongle attached as well.
Greetings Josse
tweety777
« Reply #260 on: November 28, 2025, 11:35:13 pm »
Hello all,
Recently I found some 1,5" LCD screens at Ali which appeared perfect for rudder indicators, also providing myself a chance to fix the awkward position for the rudder indicators, they seem quite useless when the side of my hand is resting atop the rudder indicator. The first screen has now been placed and I made a nice cover for all the electronics.
Now the plug is fully covered with epoxy filler the sanding can start in earnest!
Sanding will be quite a lot of work since I had a lot of trouble trying to make the filler go where I wanted it to go, especially on all the curves.
Earlier tonight I went night sailing with the modelling club, which was quite a different experience compared to sailing at daylight. Fortunately I had put some lights on the model so I could see where I was sailing. It's going to be quite a challenge the keep the amount of light in check considering the model is already very well lit (though not blinding to bystanders and the captain) but now only 15 of more then 100 floodlights are fitted, also because these lights are temporarily put in place with a bit of tape.
Greetings Josse
tweety777
« Reply #261 on: December 09, 2025, 06:33:52 pm »
Hello all,
Since I decided to use WiFi for the communication between transmitter and boat I now needed a WiFi router in the field. I found a nicely tiny and very efficient router and now needed to place it somewhere. It seems logical to put it on the water in a high place considering that this will increase the coverage of the network (along with the WiFi repeaters in both the transmitter and the boat), but this requires something to put it on. A lighthouse like the Fastnet Lighthouse south of Ireland is a perfect solution as it provides some 60cm of height above the water for the router, gives light during the night (off course the light will be working and rotating) and by adding an anchor winch which is remote controlled via an ESP32 board I can tow it to any location I want and not need to worry about water depth as well.
It took me 5 minutes to design anchor winch and 40 minutes later the 3D printer had finisht it as well. The engine and drum turned out to fit perfectly as well.
https://www.youtube.com/watch?v=fHktUdYSRrM
The winch works well and it powerful enough.
This will be the anchor making sure the lighthouse can not drift off by the wind. I made room for 2 layers of 4 blocks of lead meant for balancing car wheels. In the middle on the bottom I put a M4 threaded insert in which I will screw an eyebolt to connect the anchor chain or rope. By putting the threaded insert on the bottom it cannot be pulled out.
I made quite some headway with filling and sanding.
The bulbous bow requires quite some attention since it's not yet symmetrical.
The stern is a lot more symmetrical.
Took a pencil and a host of different types of rulers to check how close I am to the desired result, which turned out to be not as close as I thought.
After finalizing the design I printed the new power supply box. This is a lot better then what is currently in the old hull. The top plate housing a new 20x4 LCD screen and the plate holding the Raspberry Pi and it's attributes and a plate to hold all the removable plates straight are currently being printed. All plates will remain removable for maintaince purposes.
Greetings Josse
tweety777
« Reply #262 on: December 11, 2025, 06:43:45 pm »
Hello all,
While the filling and sanding continues behind the scenes I decided to shift some attention to the power supply box, also because I had a spark on inspiration on how to properly design it. The power supply will be completely redone in the new hull and the power supply box seems like a good place to start working on that. The middle row will be fully - connections for ease of connecting, the remaining connectors will be divided along 5 fuses, since the first of 6 fuses is used as a main fuse to the last 3 fuses. From this point I will run wiring throughout the boat, adding the same kind of connectors at tactical connection point in the hull.
I started applying a colour coding for the connections.
The power supply box got quite big, this is in part because it provides much more room for proper wiring and the Pi also becomes much more accessible for maintenance. I do need to find a place for the battery status display which I almost forgot about.
The new power supply box fits well, though it will end up on the bottom rather then on the old box.
I started getting a feeling that it might proof difficult to pace winches inside the drilling tower so I spent like 5 minutes in FreeCAD so I could see whether it actually will be a problem or not.
There is now better way of determining whether or not something will fit then to make it and try it out, so I did. I will use 3mm styrene sheet for basic construction of the tower (2 aluminium angle bars will provide more strength) so I won't have issues with a bending tower when all winches are lifting whatever load I may come across. At the moment the 3D printer is printing the second of 5 winches.
Both bottoms (1 will be fitted to the island, the other will be glued inside the PVC pipe that will make the lighthouse), the 2 plateaus, the roof and the mounting plate for the WiFi router. The mounting plate for the router has an additional hole for the wiring of the lighting in the top of the lighthouse.
The joysticks are now ready to be placed permanently, though I need to be careful not to forget placing the magnets otherwise there will be no angles indicated.
I finished the wiring, now I need to place the remaining 2 screens.
The right joystick is mirrored for convenience in use. Now it all comes down to detailing!
Booting the transmitters goes quite well. Today I added a battery status display so I'll know when to shut the transmitter down.
Greetings Josse
tweety777
« Reply #263 on: December 19, 2025, 06:26:18 pm »
Hello all,
Now that the power supply box is coming along nicely and more preparations for controlling the entire model are made I decided it's time to start working on the design of the middle sized crane so I can start figuring out how to make it work while maintaining view on the electronics atop the power supply box and without creating issues with the controls. The nice thing about having a filament 3D printer is that this kind of prototyping is very easy and quick to do and this makes it very easy to track down any potential problems before making all to permanent parts. I have already discovered 2 important difficulties, the first is that there appears to be very little room for a proper bend for the lower cilinder braking cable. The second is that the braking cable for the knuckle only starts to overcome the internal friction once it has the room to extend outwards, though this could also be considered a safety feature.
The 9G servo's look big compared to the crane. The braking cable is clearly visible running through the arm, it will go through the bottom of the crane about halfway and into the cilinder it will move.
In order to get a proper picture on how I can arrange the servo's and steering motor for the crane, right above the power supply box, I decided to cut the piece of deck the crane is mounted to loose from the remaining, temporary, deck so I see below with the crane in place. I also made a quick and easy support for the crane which will later be replaced by a proper scale version, possible to be permanently fixed to the superstructure below rather then to the removable deck since the crane will also be fixed to the superstructure itself.
Greetings Josse
Pages: 1 2 3 4 5 6 7 8 9 10 [11]   Go Up
Page created in 0.046 seconds with 21 queries.
