Hello Meyhemers, a total newbie here aged 57!! could do with a good bit of guidance in completing a project. I recently inherited a part built Precedent Perkasa 37" ish fiber glass hull, it came with a MFA torpedo 850 motor, brass prop shaft, 50mm 2 blade prop. The hull is fitted with all the support structures but none of the mounting brackets for motor, speed controller, servos etc, the deck is not fitted though all the superstructure is assembled.
I wanted to keep costs down so elected to keep the motor, and on the advice of a local model shop bought a Mtronix tio marine 30 ESC and a spectrum SR 301 to go with a spectrum DX4e i already had from an RC plane, i would also like to run the boat in some 3S li pos i already have too.
I managed to set the li po position on the ESC OK then wired the whole set up as shown in the wiring diags for the ESC, i then tried to bind the receiver as described in the instructions but to no avail, Doh! The ESC now has a continuously flashing led which is apparently fails safe mode.
so here are the questions.
Do I need to unbind the transmitter before I can then re bind to the new RX, If so how do i unbind.
How do i get the ESC out of fail safe mode so i can start again.
Will this TX/RX combo ever be any good for my application, I am not wanting to be a superstar model boater, I just want some thing I can mess about with occasionally.
Same goes for the the motor,ESC, battery combo, will it work, is it sufficient for the size of boat.
If I need to change any thing then please advise an alternative, i don't mind buying new parts as long as the whole thing works.
Last question for now, when I come to paint the wood deck and superstructure is there anything i can do to fill the wood grain.
Many thanks for any help
best regards
Steve C.
