Author Topic: Gluing Styrene to Wood?  (Read 7854 times)
Mark T
« on: February 01, 2014, 05:23:06 pm »
Hi All
I need to glue some styrene to wood and I require a good strong bond.  I was thinking about using zpoxy 15 minute resin after degreasing and roughing up the surface of the styrene and also applying lots of clamps?
I've never really worked with styrene before so any advice would be welcome  :-))
Thanks Mark
tobyker
Re: Gluing Styrene to Wood?
« Reply #1 on: February 01, 2014, 10:33:57 pm »
There is some stuff called UHU plus acrylit that seems to stick 'most anything to anything else - it says "Model-building plastics, stone,ceramics, Wood, Metal and Glass" (auf Deutsch) and lots of other stuff which might mean you can sand it, its workable for 7 to 10 minutes and set after 15. It is also spaltuberbrucked (that may mean gap-filling) and the pack I bought at my LMS had very basic instructioins in english inside. Its a 2-part (powder and gel) epoxy. Good stuff.
Subculture
    • Dive-in to Model submarines
« Reply #2 on: February 02, 2014, 12:01:20 am »
The epoxy you have will work very well. Just make sure you a key the plastic well so the adhesive has something to hook onto.
Mark T
« Reply #3 on: February 02, 2014, 09:52:17 am »
Thanks very much for the replies - I think I'll try the epoxy and see how I get on.  Its nice to know that at least I'm heading in the right direction  :-))
roycv
« Reply #4 on: February 02, 2014, 12:01:20 pm »
Hi Stablit Express is excellent for glueing wood to plastic and is gap filling.  It is a 2 part resin and powder adhesive.
The tube of resin once opened does not last very long, perhaps a month or two so buy just what you need.
good luck,
Roy
RMH
« Reply #5 on: February 02, 2014, 12:14:54 pm »
UHU plus Acrylit is exactly the same stuff as Stabilit Express but about half the cost either will do the job nicely. If you keep the tube of gel in the fridge it will last for a very long time
roycv
« Reply #6 on: February 02, 2014, 12:59:51 pm »
Hi RMH thanks for the information I shall make another space next to my instant glue.  My wife does give me funny looks though!
By the way I buy UHU tube glue for just 1£ in my local pound shop.  Is it the same as UHU bought elsewhere?
regards Roy
« Reply #7 on: February 02, 2014, 05:09:24 pm »
spaltüberbrückend = gap filling as previously suggested (note the umlauts)
Stan
« Reply #8 on: February 03, 2014, 12:52:26 pm »
I am now using a product called Sticks All made by Everbuild Building Products Leeds. It sticks plastic to wood with no problems and a lot cheaper than some of the glues we tend to use. Glues used in the building industry can be used by the modelling world with great results. My thoughts only.
Stan
Stan
« Reply #9 on: February 03, 2014, 12:56:25 pm »
I will post picture of Sticks All later. Available in small tube or large mastic gun size.
Stan
Subculture
« Reply #10 on: February 03, 2014, 01:57:10 pm »
Starloc adhesives sell a whole range of modified acrylic adhesives which match all the major brands at a lot lower cost.
I have used acrylic adhesives, and I think they're good, however epoxy is I think just as good for this application, and is the most inexpensive option bearing in mind Mark already has it.
If you really want to enhance the strength you could wrap some cotton, carbon or kevlar tow around the joint before applying epoxy. This forms a composite enhancing tensile strength, but is probably overkill.
Stan
« Reply #11 on: February 03, 2014, 02:19:44 pm »
Each to there own but I find epoxy to be a little dated now. Stabalit is great but very expensive UHU Ackralit has double in price in the last few years. My thoughts only.
Stan
Subculture
« Reply #12 on: February 03, 2014, 02:34:11 pm »
Acrylic glues aren't new, they've been around for decades. Epoxy will give a bond as strong if not stronger than the material it's being glued to in the vast majority of cases, so in my book, that's good enough.
Acrylic glues can also attack some plastics through crazing, epoxies in my experience are completely inert in this respect.
Stan
« Reply #13 on: February 03, 2014, 03:04:48 pm »
Hi Subculture Has I stated earlier each to there own. The glue I use is not acrylic based. I do not wish to  change peoples way of working. These are my thoughts only and I have no wish to change or influence any one.
StarLocAdhesives/FiveStar
    • StarLoc FiveStar quality adhesives and glues at FMK
« Reply #14 on: February 20, 2014, 12:27:25 pm »
While acrylic adhesives aren`t new, the technology has advanced rapidly over the past few years, we have been manufacturing acrylates and methacrylates since about 1993 and the bonds available today are far superior to other adhesives.
Methacrylates such as our superacrylate out perform almost any epoxy adhesive, the formulation possibilities are far greater with acrylic chemistry.
In general:
Acrylates or methacrylates cure at temperatures far lower than an epoxy, a lot of epoxys dont set below 10 deg C , ours does, but only down to about -10C without slowing cure a lot, our methacrylates still set at -80C with little change in cure speed
Once set methacryates have a far greater working range without either going brittle at cold temperatures or melting at higher temperatures
Most do not discolour with age
The overall strength including impact resistance is far greater especially if there is a big gap ( epoxies generally loose strength on a large gap )
The most important part for a small volume user of adhesives is that methacrylates can be formulated to be insensitive to mix ratio ( unlike epoxies that need to be exact ), our superacrylate is formulated to be an easy to mix ratio that can be out by  along way and still set.
In general epoxys dont bond well to plastics, they can be formulated to bond better to plastics but acrylates and methacrylates give a better bond to plastics and metals than epoxies
The original type diy store formulation of methacrylates ( one pink one green usually ) is very out of date now , most are virtually colourless white/beige , they are not as clear as epoxys if they are toughened as the rubber tougheneing additives work by seperating out to tiny particles when they set, this makes them almost clear in a thin layer and cloudy in a lump.
We make epoxys and we make acrylics, both would do  the job, but I would go for methacrylate as it is far tougher, longer life, and gives strength over a wide temperature range even on a gap[size=78%]  [/size]
But if you have the epoxy, use the epoxy it will work!
Formulators and manufacturers of quality adhesives and surface coatings for industrial , DIY & modelling sectors since 1988
See us online   www.shop-4-glue.com
on ebay https://www.ebay.co.uk/sch/gianthairyhedgehog/m.html?_nkw=&_armrs=1&_ipg=&_from=
Page created in 0.387 seconds with 22 queries.
