Author Topic: Motor identity?  (Read 3294 times)
Grace2
Motor identity?
« on: February 27, 2014, 01:12:43 pm »
hi, iv got a pair of these motors in my pusher tug, they are 12v and 80mm long.....im running 2x esc's and if i go full power the motors are blowing 15amp blade fuses....................can you tell me what the motors are please...........
Re: Motor identity?
« Reply #1 on: February 27, 2014, 01:26:45 pm »
That looks like a Robbe gearbox on there.... maybe Graupner or Multiplex.
John W E
  • I see no ships !!
Re: Motor identity?
« Reply #2 on: February 27, 2014, 02:49:23 pm »
hi ya
Could it be a Graupner Speed 600 with the 3 to 1 gearbox on it?
I have one here 600FG3 and its total length plus gearbox is 80 mm.   It's operating voltage is 7.2 - 12 volts.   Its idle current drain is 2 amps.  Max efficiency is 12 amps but its storl current is 85 amp.
So its a possibility.
aye
john
Knowledge begins with respect
Grace2
Re: Motor identity?
« Reply #3 on: February 27, 2014, 05:45:39 pm »
hi ya
aye
john
these motors seem quite greedy on powerits blowing 15 amp fuse if you face the bank and power it up..what are they like as motors?
Re: Motor identity?
« Reply #4 on: February 27, 2014, 09:10:40 pm »
grace.......this image suggests that the gearbox is not mounted squarely to the motor....and a certain misalignment is evident with the flexible coupling
Both of these have the potential to draw additional or excessive current...............Derek
mudway
  • Model Boat Mayhem is Great
Re: Motor identity?
« Reply #5 on: February 27, 2014, 10:19:20 pm »
The size and pitch of the props would have an impact on the amps drawn too.
How big are they?
Re: Motor identity?
« Reply #6 on: February 27, 2014, 10:48:06 pm »
I think the props are around 40mm 4 bladed ones in Kort Nozzles
Grace2
Re: Motor identity?
« Reply #7 on: February 27, 2014, 11:30:57 pm »
hi, derrek your correct when i took the pic the motor had rotated in the mount..i turned it to the correct position and used a cable tie to hold it firmly,,,
stavros is also right ..40mm 4 blade bats in a kort knozzle
