Author Topic: stanchions  (Read 2976 times)
Howard
stanchions
« on: March 03, 2014, 08:08:38 pm »
Help please gents,
Can any of you clever modellers tell me what size stanchions I,ed need for a 1:70 scale ship three ball, I have some two ball 1:72 would there be the  same size or would three ball be larger on a real ship, in mm please if you can.
 Thank you Regards Howard.
Re: stanchions
« Reply #1 on: March 04, 2014, 09:53:50 am »
The difference in scale is small enough that no-one will notice the difference.
Since stanchion height varies whether 2 or 3 hole, you need to know the height of the original.  Then you can start wondering whether the quoted height is to the top of the stanchion or the top hole.
roycv
Re: stanchions
« Reply #2 on: March 04, 2014, 10:34:35 am »
Hi all, I go by the practical use of the stanchions.  If it is a ship then you can lean on them comfortably, if it is a sailing yacht you have to step over them for taking ropes and mooring up etc. So nothing higher than the inside leg measurement!
regards Roy
Tankerman
Re: stanchions
« Reply #3 on: March 04, 2014, 04:03:32 pm »
Guard rail stanchions on merchant ships were generally between 3' 6'' and 4' high, so in 1:70 scale height would be between 15 mm and 17.5 mm
Going up to Bahrain on the Caltex Cannonball
Howard
Re: stanchions
« Reply #4 on: March 04, 2014, 06:45:31 pm »
Thank You so much Gents for your helpful replys Tankerman your replys was most useful  and i,ll go with that as it a 7foot plus SD14 that I,ll be building now to find some hopefuly at a good price as am going to need a lot of them.
                         Regards Howard.
Tankerman
Re: stanchions
« Reply #5 on: March 04, 2014, 09:25:51 pm »
Howard, an SD14 would not have had ball type stanchions, they were flat bar. The nearest match that I know of are produced in etched nickel silver to 1:72 scale by James Lane and are 13.8mm high, he can also supply rolls of soft brass wire to form the rails. I think he can still be contacted by phone on 01670 352051
I hope this helps, Chris
Howard
Re: stanchions
« Reply #6 on: March 04, 2014, 09:50:06 pm »
Tankerman, Thank you for that its a great help and I,ll write down the number.
                      Regards Howard.
Bryan Young
Re: stanchions
« Reply #7 on: March 06, 2014, 02:35:03 pm »
Jim Lane is still alive and kicking, although he doesn't advertise any more.
He also produces much more than just stanchions!
He's very helpful....and ask for his product list.    BY.
Notes from a simple seaman
