Morning Paul.......there are a number of considerations for limit switches in model structures.....
1. install the switching in the drive unit......
+ accurate repeatable positioning, ....
- difficult to attain in scale versions with the switching being relative to the pitch of the threaded hoist rod
2. install the switching externally with the load as the switching interface.....
+ easier to accurately limit of movement, .....
- can be difficult to disguise the equipment
The great image from
bluebird shows 3 of 4 lowering hydraulic cushion cylinders from Ark Royal ......the hoist frame plate comes to rest on these 4 cylinders when fully retracted....they are also load sensing so each one sends a hydraulic signal to stop the main cylinders retracting any further
It would be pretty simple to install 2 micro switches [on the diagonals under the floor of the hoist frame plate] with small tubular extensions, their function replicates that of the original
Hoisting limits could be mounted in a similar manner under the main upper deck of the carrier
I am pretty sure hoisting & lowering could be achieved by using DPDT [double pole/double throw] limit switches, however I would stand back and ask a member knowledgeable in the
Black Arts for confirmation
The image below from Ark Royal with one of the lowering hydraulic cushion cylinders shown [fully extended]....the rod spherical round landing pad is also seen in the rod closer to the camera
