Author Topic: S-Boot A Frame repair  (Read 5648 times)
Re: S-Boot A Frame repair
« Reply #25 on: May 17, 2014, 10:31:40 pm »
Many thanks David for the link  If push comes to shove may consider that though doubt I would be able to work out what s needed
Jay
Andy_k
« Reply #26 on: May 18, 2014, 05:50:05 am »
heres another option epoxy putty drill 2 small holes either side off the broken parts mix some putty position the parts together and mould the putty around the brake pushing the putty into the holes when it cures it can be filed to shape
the finish will be slightly thicker than the original part but also stronger just remove paint and roughen area around break as well as the holes  :-))
 http://www.ebay.co.uk/itm/Waterproof-Epoxy-Putty-Repair-Adhesive-Seals-Leaks-Pipes-fix-and-fill-holes-/321395086382?pt=UK_Crafts_Cardmaking_Scrapbooking_Glue_Tape_EH&hash=item4ad4a3d42e
Right which one will I do next?;)
longshanks
« Reply #27 on: May 18, 2014, 09:16:39 am »
Hi Guys
Just been out and measured the A frame in question. Each plastic leg is 9.5 x 2mm and come away from the hull at an angle.
As already stated for static display plasweld is more than man enough!
To use this in the water with a prop and shaft turning at 6 - 16000 rpm !
With a prop and shaft  that are not perfectly balanced or worse bent !
Add to that the probability of hitting a twig in the water and the stresses invlved !
Get real ! This is a plastic kit made for static display. The only realistic chance is to make brass A frames, properly lined up with 'straight' shaft. The A frames should have tabs on the inside fixed to reinforcement.
Sorry to be the bearer of bad news but in my opinion anything else is only  going to involve more wasted time/money and heartache !
longshanks
Page created in 0.268 seconds with 17 queries.
