November 24, 2025, 04:52:07 pm
Welcome,
Guest
Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Search
Calendar
Login
Register
Mess Deck: General Section
Model Boating
eze kote
« previous
next »
Pages: [
1
Go Down
Print
Author
Topic: eze kote (Read 2762 times)
boatmadman
Full Mayhemer
Offline
South Cumbria
eze kote
on:
May 11, 2014, 05:33:44 pm »
Has anyone used eze kote purely as a skinning coat without glass cloth on a boat hull?
[/size]
If so, what are your thoughts on this as an alternative to an epoxy skin (like z poxy)?Ian
barriew
Full Mayhemer
Offline
Thaxted, Essex
Re: eze kote
Reply #1 on:
May 11, 2014, 06:48:58 pm »
Yes - I've used Eze Kote, but not ZPoxy so can't compare. It doesn't leave as thick a coat as resin, but gives a hard surface which sand nicely. It is probably best if used with aircraft tissue.
Barrie
inertia
Guest
Re: eze kote
Reply #2 on:
May 11, 2014, 07:25:02 pm »
I've used Eze Kote both with and without lightweight glass cloth, and my current build is balsa with Z-Poxy resin and two layers of cloth. No comparison. Eze Kote on its own is fine for a quick finish on ply but better with cloth on balsa. Epoxy resin is hard work but the finish is far and away superior to the water-based one. Like any finish you only get back the effort you put in.
DM
boatmadman
Full Mayhemer
Offline
South Cumbria
Re: eze kote
Reply #3 on:
May 11, 2014, 09:16:38 pm »
Thanks fella's. pretty much as I expected really.
Z poxy it is then!
Print
Pages: [
1
Go Up
« previous
next »
Model Boating
eze kote
