Author Topic: eze kote  (Read 2756 times)
boatmadman
eze kote
« on: May 11, 2014, 05:33:44 pm »
Has anyone used eze kote purely as a skinning coat without glass cloth on a boat hull?[/size]If so, what are your thoughts on this as an alternative to an epoxy skin (like z poxy)?Ian
barriew
Re: eze kote
« Reply #1 on: May 11, 2014, 06:48:58 pm »
Yes - I've used Eze Kote, but not ZPoxy so can't compare. It doesn't leave as thick a coat as resin, but gives a hard surface which sand nicely. It is probably best if used with aircraft tissue.
Barrie
inertia
Re: eze kote
« Reply #2 on: May 11, 2014, 07:25:02 pm »
I've used Eze Kote both with and without lightweight glass cloth, and my current build is balsa with Z-Poxy resin and two layers of cloth. No comparison. Eze Kote on its own is fine for a quick finish on ply but better with cloth on balsa. Epoxy resin is hard work but the finish is far and away superior to the water-based one. Like any finish you only get back the effort you put in.
DM
boatmadman
Re: eze kote
« Reply #3 on: May 11, 2014, 09:16:38 pm »
Thanks fella's. pretty much as I expected really.
Z poxy it is then!
Page created in 0.016 seconds with 22 queries.
