Author Topic: Turnigy SS Series 125 A ESC  (Read 2780 times)
JamesD
« on: May 30, 2014, 05:07:26 pm »
Can anyone tell me when you give the above esc full throttle,why does it take between 5-6 seconds before it responds to the command.
sparkey
Re: Turnigy SS Series 125 A ESC
« Reply #1 on: May 30, 2014, 05:29:49 pm »
 :-)) I have got two of these ESCs in my boats and had no problems at all,I would think if it was faulty it would not work at all, maybe a radio problem or programming I don't know just have to try everything receiver,BEC voltage,interference of signal,sorry cant be of more help might take some time to sort out these bugs always do,Ray. ok2 ok2
« Reply #2 on: May 30, 2014, 06:46:16 pm »
Silly question but have you initialised it? (set the end points)
kmmbcwebmaster
    • Kingsmill MBC
« Reply #3 on: May 30, 2014, 09:56:22 pm »
May be another silly question but have you set it up with a programming card
just tugging along
JamesD
« Reply #4 on: May 30, 2014, 10:04:56 pm »
No. I dont think you cant get one for this esc
sparkey
« Reply #5 on: May 31, 2014, 06:44:55 am »
Should run OK without programme card on factory settings,only really need one to tinker around with settings although you might need one on some ESCs to get reverse as factory setting does include this,you can of cause set it up on the pleeps and you can find programming information on the hobbyking websight or there is a video on utube about programming,best to print instructions out as it makes it easer,hope I have been of some help,Ray.
« Reply #6 on: May 31, 2014, 10:55:30 am »
Page created in 0.017 seconds with 22 queries.
