Author Topic: CLYDE PUFFER  (Read 3978 times)
Rottweiler
CLYDE PUFFER
« on: June 11, 2014, 01:43:12 pm »
A pal is building a Clyde Puffer,and I can only find  one similar build here on Mayhem.However,that build uses a Decaperm 6 volt motor,which is pretty expensive.Could anyone advise him of any alternatives to use please? I am not sure which scale his is, so could replies include suggestions for both scales of Puffer please?
Many Thanks
Mick F
gingyer
Re: CLYDE PUFFER
« Reply #1 on: June 11, 2014, 02:04:52 pm »
Mick,
you may want to check the size first as there are kits and semi kits out for them
in 1:72, 1:32, 1:48 and 1:24th scale.
if it was a decaperm you would be looking for something similar to a 545 geared motor
easy-ish solution is a motor that is about 2500 to 3000RPM and the same diameter as the prop
they were not fast they just puffed along  :embarrassed:
Rottweiler
Re: CLYDE PUFFER
« Reply #2 on: June 11, 2014, 02:29:36 pm »
Thanks gingyer,
he is bringing it round tonight so I will check the measurements.I just wanted to be forearmed with some info to pass on to him.I must admit I had forgotten about the motor to prop size comparison!
Thanks,
Matey,
Mick
Re: CLYDE PUFFER
« Reply #3 on: June 11, 2014, 02:33:50 pm »
a 555 or 585 will do admirably for the Mountfleet or the Calder craft models........that's what I put in the caldercraft one and would do with the Mountfleet if a buhler wasn't available....they were a max 8 knot ship anyway and you don't want the ol gal to behave like a Shannon, lol
mikearace
Re: CLYDE PUFFER
« Reply #4 on: June 11, 2014, 02:52:11 pm »
I used an MFA 500 on my  caldercraft one and it chugs away quite nicely.  Also ready wired and suppressed so saved me a job that I am useless at.  Amongst other jobs I am useless at of course.
.........never trust a hippie
inertia
morley bill 1
Re: CLYDE PUFFER
« Reply #6 on: June 11, 2014, 07:39:33 pm »
Put a buhler in my 1/24 highlander & a 60mm prop shop prop pushes it well with power to spare regards Bill.....
Buccaneer
Re: CLYDE PUFFER
« Reply #7 on: June 11, 2014, 08:59:15 pm »
I use a Mabuchi 555 on my Mountfleet Highlander, 33 inches long. It is fitted/ballasted with 2 x 12V 5 A/Hr sealed gel batteries and goes for ever. 2 hours round the lake this afternoon and still lots of go at the end.
cos918
Rottweiler
Re: CLYDE PUFFER
« Reply #9 on: June 12, 2014, 01:31:15 pm »
Thanks Guys,for all the replies.
I have since found out the sizes of his boat,his measurements not mine in old English
33 and 3/4 inches long, and 10 and 1/2 on the beam. does this make it 1/32nd scale please?
Its strange, because I saw one as a diorama the other day and those measurements were very slightly different  at 33 inches long and 7 and 1/2 inches Beam.
I also have a four bladed prop of 1 and 3/4 inch diameter which seems ok?
Re: CLYDE PUFFER
« Reply #10 on: June 12, 2014, 03:19:41 pm »
1/24th methinks.
Original puffers were about 66 feet loa to use the
canal locks.
html
  • Gipping Valley Model Boat Club
Re: CLYDE PUFFER
« Reply #11 on: June 12, 2014, 08:47:30 pm »
I have a 1/32nd Mountfleet puffer, and it is powered by a 550 motor, the model weights about 4kg when all the batteries are in it. It still has a good turn of speed when required but equally goes along nicely at scale speed
I do not suffer insanity, I quite like it!
Page created in 0.126 seconds with 22 queries.
