Author Topic: Cirrus servo fly lead  (Read 5502 times)
david48
« on: July 24, 2014, 12:41:01 am »
Please can some one tell me the way the plug from the servo goes into the receiver . The colors are brown Orange  yellow . Do I plug it in with brown to the numbers on the receiver or brown to the out side .
Thank you for the help yet again
David
Re: Cirrus servo fly lead
« Reply #1 on: July 24, 2014, 02:26:54 am »
David....
1. wire colours can vary between manufacturers <*<
2. most rectangular RC plugs are a 7.46 x 2.46 mm envelope
3. look at the images below......you will see two small 45 degree chamfers along one of the 7.46 mm faces
4. the receiver will also have the same sized corresponding chamfers
Just align them up & insert to connect  :-)) ...Derek
Peter Fitness
« Reply #2 on: July 24, 2014, 05:23:13 am »
As a general rule, the black or brown wire goes to the outside of the receiver.
Peter.
« Reply #3 on: July 24, 2014, 06:07:16 am »
David...trust your glasses & not any potential colour blindness
1. stick with the chamfers  :-)) ...or reread you RC gear manufacturers manual
2. as previously mentioned, wire colours can vary between manufacturers
3. JR [Japanese Radio] have  <*< as the closest wire to the external side of a receiver as orange
david48
« Reply #4 on: July 24, 2014, 07:05:29 am »
Thank you for the info , I will use brown to out side ,the plugs will go in eather way round ,hence the question .
Thanks again
David
« Reply #5 on: July 24, 2014, 07:19:41 am »
The pin closest to the edge of the PCB is the Common
black or brown.
In Derek's picture the pins are L shaped so the lower pin is
nearest the edge of the board and has the black wire on it.
« Reply #6 on: July 24, 2014, 08:22:13 am »
Just to clarify my last post, a couple of pics showing
pin configurations top and end.
« Reply #7 on: July 24, 2014, 09:21:14 am »
Goodness to mercy......... :D
Orange is outer near the chamfer
Brown is opposite outer near the chamfer
This only leaves Red as the central inboard common +
Just get your specs at home.......just put them on 45 degree taper chamfers to match the 45 degree taper chamfers   ...if you do that all will be OK  O0
Peter Fitness
« Reply #8 on: July 25, 2014, 03:22:47 am »
Derek, with all due respect, your advice is good, but some of my receivers will accept the plugs in any direction, so I make sure the black/brown wire is to the outer edge of the receiver. BTW, I wear glasses all the time, otherwise I forget where I put them. :-)
Peter.
RAAArtyGunner
« Reply #9 on: July 25, 2014, 04:25:32 am »
Peter.
I can definitely relate to that, need a spare set of glasses to find the originals.
Back to topic,
Recall a thread that some servo plugs have an extension, like a small "L" which when cut off will allow the servo to fit other receivers, not to mention chamfering a square plug to fit chamfered receivers, the positioning of black/brown colour lead then becomes critical as there is no longer a 'key' for correct orientation of the plug.
The photo of plugs and receivers by Netleyned explains it all admirably.  O0 O0 :-)) :-))
« Reply #10 on: July 25, 2014, 04:36:58 am »
Hullo Peter...... %) I also wear my glasses [except in the shower or when asleep]   :}
As I have acknowledged......my understanding of the "black arts" is minimal...so if you can insert the RC connection plug wiring looms ...either/or......back to front or front to back.....does this reverse the functionality of the servo?
Interestingly.......the JR manual for their XF631 system displays the previously mentioned 45 degree chamfers in the Rx socket bays.......but make no reference to these chamfers ...or the corresponding chamfers in the plugs   <*< ......Derek
« Reply #11 on: July 25, 2014, 11:20:53 am »
Different manufacturers like their products to not quite fit anybody elses.  Having a keyed case and a matching shaped plug stops you plugging a servo in backwards, but not if you stray from their true path.
Fortunately, with modern plugs with 3 connectors, plugging them in reversed does nothing since the ground line from the RX is connected to a dead end, and the signal pin connects to the servo ground line, the pos power staying put.
I have always found that the safest bet is to figure out where the RX board is, and assume that the pins nearest the edge of the board are the neg, or ground, line, and plug the servo in with the black or brown on that pin.  On some sets, it is quite easy to shove the plug between the rows of pins.  I have found that this doesn't work, either.
david48
« Reply #12 on: July 25, 2014, 08:38:35 pm »
When I asked the question I thought it would be a simple answer,don't things get complicated very easy .Well one and all thanks for the input
David
RAAArtyGunner
« Reply #13 on: July 25, 2014, 10:29:34 pm »
As Derek says the Black arts have never been simple,  {:-{ :(( hence why we have Wizards on site  O0 O0 who steer us novices in the right direction :-)) :-))
Page created in 0.984 seconds with 22 queries.
