Pages: [1] 2 3   Go Down
Author Topic: ASD hull from MMB  (Read 24957 times)
cuppa
ASD hull from MMB
« on: July 24, 2014, 10:23:35 pm »
Picked up an ASD tug hull from Mark's Model Bit's this morning.
Really nice hull and very, very strong. I am well impressed.
Spent a bit of time chatting to Mark - a really helpful and friendly chap.
mark w
  • "I stick my neck out for nobody"
Re: ASD hull from MMB
« Reply #1 on: July 24, 2014, 11:07:21 pm »
Cuppa,
Bought a semi kit from Mark last year (he no longer carries it  :(( ), was very easy to deal with, had no problem shipping to the states.
Mark
"If she can stand it, I can too, play it"
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
lets just hope this one floats !!
fire at will ! ... which one is will ?
cuppa
« Reply #4 on: July 26, 2014, 06:55:29 am »
Thanks chaps
Nice build Ian.
I am going to use a single 60mm kort on mine.
cuppa
« Reply #5 on: July 28, 2014, 11:47:39 am »
Have been getting the hull prepped for the build and sorting shaft, kort, motor, coupling and prop.
will post some pictures when it reaches the 'interesting' stage if anyone is interested (I know builds on this hull have already been posted by others far more skilled than I am).
The ASD is a great hull and excellent value for money. I just hope I can do it justice.............
ian-mccaffrey
« Reply #6 on: July 28, 2014, 01:34:07 pm »
please do post pics of your build mate. Every build is different and every one does them different
Will you be using standard props and shafts with steerable kortz nozzles. Or will you be using steerable asd units from graupner ?
ian-mccaffrey
« Reply #7 on: July 28, 2014, 01:35:14 pm »
Sorry. Didn't read your post correctly lol :embarrassed:
Look forward to seeing photos of the build
ian-mccaffrey
« Reply #8 on: July 28, 2014, 01:36:02 pm »
And do a build log. Every stage of the build is interesting !!
mark w
« Reply #9 on: July 28, 2014, 04:31:32 pm »
+1.
Mark
« Reply #10 on: July 28, 2014, 05:45:25 pm »
Remember Mark showing the prototype at Wick steed  2010
It danced around the pond :-))
Not sure what running gear it had but it was impressive.
Its still on my top five of models to make before crossing the bar.
slug
« Reply #11 on: July 28, 2014, 07:37:51 pm »
I think that he used the motors etc as per semi kit....tony......ps my mate made one with a 70mm prop...nearly planes
ian-mccaffrey
« Reply #12 on: July 29, 2014, 12:07:37 pm »
mine did plane !! Ask mark from mmb
cuppa
« Reply #13 on: August 01, 2014, 10:30:09 am »
OK - here is the first picture. 60mm kort and the 5mm propshaft. Not bonded in yet as I have to get a P frame to support the shaft - I don't fancy hanging a 60mm brass prop on the end of the propshaft without it having some support.
ian-mccaffrey
« Reply #14 on: August 01, 2014, 10:46:21 am »
i put a p frame in mine but front it wasn't strong enough . so i decided to put wedges in there instead .. worked a lot better
cuppa
« Reply #15 on: August 01, 2014, 10:57:21 am »
i put a p frame in mine but fount it wasnt strong enough . so i decided to put wedges in there instead .. worked a lot better
Thanks for the tip Ian - so a plywood fillet between the propshaft and the hull would be the best bet?
            Jon
ian-mccaffrey
« Reply #16 on: August 01, 2014, 11:02:19 am »
thats what worked best for me ! :-))
cuppa
« Reply #17 on: August 01, 2014, 11:28:53 am »
Thanks Ian
cuppa
« Reply #18 on: August 01, 2014, 11:37:47 am »
postman has just delivered the 755 motor from Action Electronics - man that is one big motor! It is the motor that Mark recommended for a large single kort installation for the ASD hull. Next job is to make up a motor mount then solder some wires and capacitors on to the motor and then run it in.
ian-mccaffrey
« Reply #19 on: August 01, 2014, 12:33:28 pm »
Ooh. Just a thought too. Don't know if you can see on my picture. But I havn't used the bits that you got to stick to the kort nozzle for the rudder post to fit in to because I found that the angle of the prop shaft was too great
cuppa
« Reply #20 on: August 01, 2014, 01:31:13 pm »
Thanks Ian
Your help is much appreciated. I am now busy trying to reduce the propshaft angle as much as possible,
ian-mccaffrey
« Reply #21 on: August 01, 2014, 01:38:12 pm »
Thanks Ian
no problem mate don't want to tell you how to build it because we all build to out own ways. Just pointing out what worked best for me
cuppa
« Reply #22 on: August 03, 2014, 03:30:48 pm »
Slight change of plan in the propulsion system area. I have decided to use a fixed kort and rudder - just a system I prefer so am going ahead and modifying the kort to make it fixed.
« Reply #23 on: August 03, 2014, 04:36:33 pm »
Hiya Cuppa,
I was thinking of fitting a Kort as well but my Propeller has rounded tips  !!    Am I correct in saying the ends have to be flat, just missing the wall of the Kort tube.  ?
Ken
ian-mccaffrey
« Reply #24 on: August 03, 2014, 05:26:33 pm »
Hiya Cuppa,
Ken
ken. On real boats. Yes. On models it would t make much difference
Pages: [1] 2 3   Go Up
Page created in 0.021 seconds with 22 queries.
