Pages: 1 2 [3]   Go Down
Author Topic: ASD hull from MMB  (Read 25086 times)
Re: ASD hull from MMB
« Reply #50 on: August 28, 2014, 08:50:46 am »
I have found just the opposite with my model korts.
My Seaport tug with the original prop and nozzle picks up
weed.reeds and small plastic bags with ease.
My springer with a kort nozzle and flat bladed prop
does not have the problem.
ian-mccaffrey
  • roll on mayhem at wicksteed 2016 !
« Reply #51 on: August 28, 2014, 09:03:55 am »
Here is a picture I me sitting inside the kortz nozzle of the real tug that this kit makes up. Also my profile picture. The svitzer sun
lets just hope this one floats !!
fire at will ! ... which one is will ?
cuppa
« Reply #52 on: August 28, 2014, 07:10:45 pm »
Excellent picture Ian
cuppa
« Reply #53 on: September 02, 2014, 11:06:24 pm »
Have now glassed the motor mount etc in using fiberglass paste as opposed to filler - much better. Thanks chaps.
cuppa
« Reply #54 on: September 10, 2014, 08:49:10 am »
Stavros was quite correct - as per my previous post I applied some pressure to the filler fitted motor mount and was able to 'remove' it. So I have removed all the parts I had fixed in with filler, removed any remaining filler from the areas where those parts were adhered, made up a new motor mount and have now fixed everything with fiberglass paste. Much, much stronger - a 'proper' job. Today I have to make up battery mounts and and an internal propshaft support. A big thank you to Stavros for saving me from a potential disaster when operating the model..........
« Reply #55 on: September 10, 2014, 09:28:50 am »
Glad to be of help
cuppa
« Reply #56 on: September 11, 2014, 08:28:54 am »
Propshaft support and battery 'boxes' now installed:
ian-mccaffrey
« Reply #57 on: September 11, 2014, 10:34:53 am »
Very nice and neat job mate !!
cuppa
« Reply #58 on: September 12, 2014, 12:18:08 pm »
Thanks Ian.
I have now added the 'power panel':
cuppa
« Reply #59 on: September 22, 2014, 10:40:23 am »
Well - I changed my mind once again and decided to go with a fixed kort and rudder. Next problem was where and how to get a suitable rudder. In the end I decided to go with a standard shop bought rudder as a starting point and then build up laminations of ply around it and then sand it to shape. I hope the final result of these labours is not too too bad.........
« Reply #60 on: September 22, 2014, 08:01:24 pm »
Hiya Jon,
You may want to round the corners of the rudder a bit more to enable better water flow with no  'Eddie-currents'
cuppa
« Reply #61 on: September 22, 2014, 08:46:29 pm »
Thanks Ken - will do
cuppa
« Reply #62 on: September 26, 2014, 01:48:34 pm »
Now I am starting to think about the best way to do the deck and its support framework and indeed what material to use in their construction. Probably I will go with a plastic deck and a wooden support framework. I also plan to fit a towing hook in case we ever feel the urgent need to tow something. So that will need a fairly hefty support under the deck. Seem to have spent the majority of this week dealing with medical matters so have not had much time for boats this week.
cuppa
« Reply #63 on: October 06, 2014, 08:31:45 pm »
Today I wired up the basic electrics - all works ok and I will post a picture when I have neatened them up a tad...................
cuppa
« Reply #64 on: October 07, 2014, 04:05:11 pm »
Here is the basic electrical system in situ. Still looks a bit like a squirrel's nest but please pardon that...
roycv
« Reply #65 on: October 07, 2014, 04:51:34 pm »
Looks all bright and bushy tailed to me.
Roy
cuppa
« Reply #66 on: October 10, 2014, 07:32:28 pm »
Thanks Roy
i am now trying to pluck up the courage to do the deck.......................................................
ian-mccaffrey
« Reply #67 on: March 26, 2015, 04:31:16 pm »
how you getting on with this build john ?
cuppa
« Reply #68 on: April 12, 2015, 10:04:10 pm »
Hi Ian
Sorry about the slay in replying. I put the tug on hold for a while so I could gain some more experience before cracking on with it. I hope to getting on with it in about 2-3 months time.
Pages: 1 2 [3]   Go Up
