well, that was one hell of a struggle to split the mould of the hull.........especially with the deck also playing against the hull halves...........and finally on removing the deck mould, there was slight damage to the gelcoat on the fore hatch which will have to be filled and sanded down, with a small amount of gelcoat to fill the hole.
the paint work on the hull plug has been damaged, but little else in the process, but because of the hull shape, especially the tumbleholme on the fore bow area it has been a tricky mould to separate from the plug.
Mike Pendlebury, aka Gribeauval made the plug, and with my agreement used polyurethane varnish to finish the hull plug............I now wonder in hindsight, even though the usual release agents were used, may be the polyester resin in the grp might have acted as a bond to this rather than a barrier and that is why it took so much brute force to separate the mould from the plug.
