Author Topic: Quick charging question..  (Read 4278 times)
U-33
  • K-157 Vepr. Akula-11
« on: September 19, 2014, 11:13:22 am »
Am I ok to be charging a 7.2v 1600a/h nimh pack at 250m/a?
Re: Quick charging question..
« Reply #1 on: September 19, 2014, 11:33:19 am »
Cant see any reason why not BUT it will take around 8 hours to charge
« Reply #2 on: September 19, 2014, 11:37:03 am »
This is a good question.
@ Dave.  What do recommend the maximum charge rate could be please.
ken
U-33
« Reply #3 on: September 19, 2014, 11:37:32 am »
Cheers Dave, I'm in no rush to use it, so that'll do nicely.
Thanks mate,
« Reply #4 on: September 19, 2014, 11:47:02 am »
Ken to be perfectly honest with you and this is a PERSONAL view on this the max charge I would say would be 1600milliamps....you should never charge ANY batt at a higher charge rate than what is stated on the batt.
I have been charging batts similar to this at a couple of milliamps below the stated capacity and have never had a problem....some of my batts are now over 6years old and are still as good as new.
2200minh would be charged at 2000milliamps.........OR poss lower....some of the batts will not allow a higher rate on my charger,I get volts cell error and all I do is either Lower or Put up the charge rate accordingly....I must admit I have cheated and put the charge rate on all my batts with a permanent marker.
Robert Davies
« Reply #5 on: September 19, 2014, 12:00:21 pm »
ken
WARNING - this advice apples to HIGH QUALITY CELLS ONLY!! - if in doubt ASK!
If I can pick up on this - with high quality cells, of which the illustrated cells VapexTech(VP), I consider the very best, I have charged at the same rate as the capacity with no ill effects at all
eg Battery capacity in this case 1600mah, charge at 1600mah - the greater number of my batteries are 5000mah, so I charge at 5000mah.
Now, because VP batteries are high quality, I have charged them at or above double their noted capacity (1600mah battery charged at 3200mah) but have on occasion played a deskfan across them to cool them as they were charging and for 10->15 mins AFTERWARDS too.
High quality cells are made by VP, GP, and Sanyo - I have found others to work OK too, but only selectively within the brand  - say 2500mah brand X are fine - but the rest within brand X are somewhat dubious.
« Reply #6 on: September 19, 2014, 07:57:01 pm »
Well worth knowing guys.  Thanks for that.
Ken
U-33
« Reply #7 on: September 19, 2014, 08:54:12 pm »
I'll second that, Ken...very useful information. Thanks fellas..
« Reply #8 on: September 19, 2014, 09:10:20 pm »
With the NimH I find charging at the rates listed above (for example 1600mah pack at 1.6A) to give the best results. However I like to fully discharge (using the discharge feature on my charger) and then overnight trickle charge every 4th or 5th "fast" charge
Tombsy
« Reply #9 on: September 20, 2014, 07:45:44 pm »
Just an aside, the above info is also considered a "1C" charge on a lipo battery. E.G. 5 amps for a 5000mah pack, 1.6 amps for a 1600mah pack.
Brian
Klunk
« Reply #10 on: September 21, 2014, 09:18:23 am »
Ok I'm more than a little confused.
Just to get it in my head.....
Slow charge I normally do at 1/ 10 of mahis of battery.
Fast charge your saying is done at  just below max ma of battery?
full time penguin
