Author Topic: Motorised Coal Barge  (Read 2873 times)
lakeshore
« on: September 20, 2014, 11:33:35 am »
Hi
A little input needed with this next project of a 36 x 10 x 6 inch Birch Ply Motorised Coal Barge.
It will be powered by 2 sla batteries running through a Mtroniks Viper Marine 25. Now we come to the input and question of the motor, as there is plenty of room I was thinking along the lines of using a car blower motor and wondered if anyone has or is using this type of motor for some info.
John,
tugboyben
  • Kirkleesmodelboatclub
  • HIGHNOON TUG BOAT
Re: Motorised Coal Barge
« Reply #1 on: September 20, 2014, 11:42:24 am »
Morning lakeshore
I use blower motor's in my tug's they run about 5000rpm on 12volt's + you can use them direct  drive a mate of mine as a 43inch tug fitted with a car blower motor  direct drive running a 80MM  4 blade prop & it go's well + give's long run time's
What size prop will you be fitting  to your barge
Jason
lakeshore
« Reply #2 on: September 20, 2014, 11:50:04 am »
Hi Jason
not had any thoughts as yet as to prop size need some info on the motors first as to makes size fitting etc.
« Reply #3 on: September 20, 2014, 12:47:36 pm »
a very good choice from Tugboyben, and many tug guys.............and these motors would throw a prop of upto 90mm on your small barge all day long..........but you wouldn't need props anywhere near that size for your craft.......probably 60mm at the most. neil.
« Reply #4 on: September 20, 2014, 01:32:00 pm »
 O0....
1. A little pointless asking the same question in two separate posts  >>:-(
2. Read the other post too!.........................
3. They will still confirm the same answer......... :-))
lakeshore
« Reply #5 on: September 20, 2014, 03:11:58 pm »
Its all in the quest for information Derek.
tugboyben
  • HIGHNOON TUG BOAT
« Reply #6 on: September 20, 2014, 04:51:42 pm »
Hi John
A member of the forum had these motor's for sale
The second picture is a pair of blower motor's may be send him a message to see if they are still for sale  :-)
http://www.modelboatmayhem.co.uk/forum/index.php/topic,48532.0.html
Jason
lakeshore
« Reply #7 on: September 22, 2014, 08:36:40 am »
Thanks Jason
I am in contact with him
John.
