Author Topic: what extras for this kit ?  (Read 4527 times)
Mike0001
« on: September 24, 2014, 01:10:00 pm »
need some help going to purchase this fast starter kit
http://www.deansmarine.co.uk/shop/product_info.php/products_id/213
been recommended the following via email but need help with what it means
black 400 motor
esc 1
coupling nycexl
2000 ah battery nimh
anyone point me in direction to purchase the extras, still getting up to speed with this all  means
radiojoe
Re: what extras for this kit ?
« Reply #1 on: September 24, 2014, 02:13:18 pm »
Hi Mike
My advise would be to go ahead and get the kit, the instruction book in the kit will tell you exactly what running gear you need IE. Motor,  ESC amperage, and the size of the nycrome coupling, the 7.2 volt nimh battery can over 2000 mah if you want a longer running time but the higher the capacity the more expensive, there is plenty to be getting on with while you wait for the "bits" to come, preparing the hull etc. :-))
Joe.
« Reply #2 on: September 24, 2014, 02:16:37 pm »
I was at Deans Marine just yesterday.... it was Ron's birthday.... but I didn't get offered any cake!  >>:-(
The extras are:
Black 400 motor - the motor to power the boat "Black 400" is the name of type of motor.
esc 1               - ESC = Electronic Speed Controller. Allows Remote / radio control of the boat speed, both ahead & astern.
coupling nycexl  - Flexible coupling, used between motor and prop shaft.
2000 ah battery nimh - Main power battery.
You will also need other bits and pieces, radio set, tools, glues, wire, paint, battery charger, etc. etc
hmsantrim
« Reply #3 on: September 24, 2014, 02:34:37 pm »
Hi Mike.
 Black 400 motor,  deans product / recommended motor  although others of a similar size could be used.
 ESC= Elctronic Speed Controller
 nycexl coupling = deans own product to join motor to prop shaft although the most  common product is the Huco coupler.
 2000 ah battery nimh = 2 amp / hour Nickel-Metal Hydride commonly called a race pack
huco coupler
nimh pack
frank
« Reply #4 on: September 24, 2014, 04:09:39 pm »
Note that the coupling ends need to match the prop shaft and motor spindle diameters. Also they come with single and double joints. The double joints are more forgiving of slight motor/prop shaft misalignment.
« Reply #5 on: September 24, 2014, 04:36:44 pm »
And noisier %)
« Reply #6 on: September 24, 2014, 05:08:01 pm »
And noisier %)
Not in my boats. You must be doing something wrong!  :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-)
« Reply #7 on: September 24, 2014, 05:10:34 pm »
Dont use them :o
MMB couplings for me :-))
« Reply #8 on: September 24, 2014, 05:32:55 pm »
You must have had a bad one, one of best couplings I've used.
« Reply #9 on: September 24, 2014, 06:13:21 pm »
Not the Hucos surely Martin?
I like Marks and I also have used Mobile Marine.
Not tried Deans.
Are we at cross purposes here?
Mike0001
« Reply #10 on: September 24, 2014, 07:56:54 pm »
I am here looking for motors ?
http://www.deansmarine.co.uk/shop/index.php/cPath/5_13/sort/2a/page/1
Been told esc 1 ? would someone enlighten me to what the differences are between 1,2, etc
http://www.deansmarine.co.uk/shop/index.php/cPath/5_29/sort/2a/page/1
completely new to this and every post is knowledge  :-))
raflaunches
  • The Penguins are coming!!!
« Reply #11 on: September 24, 2014, 08:12:14 pm »
Hi Mike
I'm guessing looking at the pictures next to the ones you're looking at the number indicates the amperage of the ESC eg ESC 3 means 3Amp.
Only a guess.
Nick B
Illegitimi non carborundum!
hmsantrim
« Reply #12 on: September 24, 2014, 11:42:07 pm »
 Hi Mike.
 I would say the 1 after esc means qty is one, as its a single shaft model. A 1 amp esc would not be large enough for the crash tender it would need more like 15- 20 amps size as its a model that should go up on the plane on the occassion as seen here.
http://www.vintagemodelworks.co.uk/?page_id=18
not familiar with Deans motors but something like his would  do or 550 size
http://www.ebay.co.uk/itm/JOHNSON-TC785LG-ES-Model-Boat-Plane-Hobby-Generator-Racing-Car-Motor-12-Volt-V-/181535094395?pt=UK_ToysGames_RadioControlled_JN&hash=item2a4455b67b
 frank
