Author Topic: US Navy crew figures?  (Read 2715 times)
tonyH
« on: October 02, 2014, 09:03:01 pm »
Evening All!
Can anyone suggest a source of US Navy figures at 1:72, WWII style please.
Many Thanks
TonyH
Ian K
  • In the workshop, going daft but happy!!
baloo
  • I`M YOUR FRIENDLY TRUCKER
Re: US Navy crew figures?
« Reply #2 on: October 03, 2014, 09:45:05 am »
There could be a possibility that Deans Marine might have some as well
baloo
hmsantrim
« Reply #4 on: October 03, 2014, 01:02:35 pm »
Hi Tony.
 I would recommend you buy the hasegawa set as you will get about 10 figures you can paint up in working rig ie lt blue shirt and denim breeks as in second url.  Buy some officers just to populate the bridge as at £8-£10 for three resin figures you wont be buying many of them.
 Frank
 http://www.ebay.co.uk/itm/Hasegawa-1-72-U-S-Pilot-Ground-Crew-Set-HSG35007-/221541361616?pt=UK_ToysGames_ModelKits_ModelKits_JN&hash=item3394e4e7d0
http://www.ussnclivinghistory.com/uniformdescription.html
tonyH
« Reply #5 on: October 05, 2014, 12:02:53 pm »
Thanks all for the sources.
I'm going to go for the cheapest option because the figures are for a Flower Class converted to a USPG (eg USS Spry) and I want to use it when the going gets rough, so I'll need to add a lot of oilskins etc.
Of course, if anyone knows of a source of appropriately dressed figures......................
Tony :-))
hmsantrim
« Reply #6 on: October 05, 2014, 04:27:33 pm »
Hi Tony.
 well if you are doing the ubiquitous flower class kit you do get some figures with it and if you want oily skins there is always here
 http://www.gunthwaite.co.uk/  but again not cheap.
 seems someone else has built this model heres a build log.
http://theflowerclasscorvetteforums.yuku.com/topic/1277/Log-Building-an-American-Flower#.USbFpldZPng
 frank
Brian60
« Reply #7 on: October 05, 2014, 04:31:35 pm »
Airfix do a wide range of models and figures in 1/72nd. You could do worse than check out their website.
tonyH
« Reply #8 on: October 05, 2014, 08:27:31 pm »
Cheers again chaps!
I'd noticed the thread on the Flower forum, but it seems to peter out half way? I hadn't noticed the Gunthwaite stuff but I can't find any US figures.
Airfix or similar may be the last resort, but they'd need a lot of work. I'm in the middle of putting red pompoms on the hats of about 40 1:96 French matelots so I thought I'd look for something a little simpler!
Tony :-))
PS The answer to the pompoms is so called Caviar Beads at about 0.5mm diameter, used for fingernail decoration
Page created in 0.572 seconds with 21 queries.
