Author Topic: RPM  (Read 3453 times)
Leaky Bottom
RPM
« on: October 04, 2014, 03:46:59 pm »
Hello
What's the best way to measure the RPM of a electric motor in a boat, I can do it with aeroplane motors with a tachometer on the prop but that's not possible on a boat when it's in the water.
flashtwo
Leaky Bottom
Re: RPM
« Reply #2 on: October 04, 2014, 06:24:43 pm »
Thanks for the links
I did realise I was going to need a tachometer but where would I take the readings from? A tachometer won't read from just a plain spinning shaft.
Big Ada
Re: RPM
« Reply #3 on: October 04, 2014, 06:31:06 pm »
Put a bit of sticky tape on it to provide when a turn has been made.
NFMike
Re: RPM
« Reply #4 on: October 04, 2014, 06:32:33 pm »
For an optical tach paint a section of shaft matt black and then paint a longitudinal white stripe over it.
chuffy
Re: RPM
« Reply #5 on: October 05, 2014, 08:03:56 am »
Most Tachometers that you can buy today come with a short lenth of reflective tape which will last for ages. I cut a little piece about 4mm x 8mm and stick on one blade, mine has remained stuck to the blade for at least two years now. Why reflective?, I don't know but it was supplied with the meter and it works, so good enough for me.
Paul.
The severity of the itch is inversely proportional to the length of your reach.
david48
Re: RPM
« Reply #6 on: October 05, 2014, 08:51:15 am »
To refect the light back to the sensor I have a couple that work like that . The none contact type are safer to use
David
flashtwo
Re: RPM
« Reply #7 on: October 05, 2014, 01:39:34 pm »
The only problem with the reflective type, is if the optics get dirty. This is not a problem when you're taking the odd reading or the conditions are clean, but, in my application with a steam powered boat, there was a lot of steam and oil about, so I fitted a magnetic (Hall Effect) tachometer, which was immune from the dirt.
Subculture
    • Dive-in to Model submarines
Re: RPM
« Reply #8 on: October 05, 2014, 02:35:12 pm »
Cycle computers are cheap (under two quid on ebay e.g. http://tinyurl.com/n54up8r) and can be used to measure RPM.
http://www.reuk.co.uk/Use-a-Cycle-Computer-to-Measure-Turbine-RPM.htm
mrlownotes
Re: RPM
« Reply #9 on: October 05, 2014, 06:11:23 pm »
A tad more ££s but it measures/tracks/logs/stores much more than just RPM.
I use a MicroPower e-logger supplied by RC_LOG.
The Optical RPM sensor and the Micropanel LCD provide Max/Min/Ave for  Amps/Volts/Watts/RPM.
Data is displayed 'live' on the LCD or you can download the data after a run to examine it in detail.
The LCD display is configurable from the PC software.
If you like to know what's going on electrically ...................
http://www.rc-log.co.uk/micropower-e-logger.html?p=1
http://www.rc-log.co.uk/micropower-e-logger.html?p=2
Bintur Ellenbach
Subculture
Re: RPM
« Reply #10 on: October 05, 2014, 07:05:17 pm »
I use a micro logger. Nice bit of kit, but utter overkill if you only want to measure RPM.
