Author Topic: Real glass windows  (Read 6151 times)
captain bligh
  • Boats oh'd av um
Real glass windows
« on: November 16, 2014, 10:19:04 pm »
Hi all
Does anyone know what the thinnest glass available to use for wheelhouse windows ?
It's not a bad man who makes a mistake its a good man who can get over it.
SailorGreg
Re: Real glass windows
« Reply #1 on: November 16, 2014, 10:26:11 pm »
 Microscope slides? Like these http://www.ebay.co.uk/itm/100-New-Glass-24x50mm-Coverslips-for-Microscope-Slides-/330462616636 .  No personal experience of them but they look like they might suit.
captain bligh
  • Boats oh'd av um
« Reply #2 on: November 16, 2014, 10:30:48 pm »
Thanks for that just thought of that myself and looked on ebay and hey bingo !!!
captain bligh
  • Boats oh'd av um
« Reply #3 on: November 16, 2014, 10:57:39 pm »
Just ordered some glass slides perfect  :-)) :-))
Brian60
« Reply #4 on: November 17, 2014, 08:30:30 am »
I can see a problem using glass, how are you going to shape it for anything other than square or rectangular windows? Then there is the safety angle if any of it breaks at lakeside- you may be ok with a cut finger, but what about if anyone else cuts themselves? could be a where theres blame theres a claim scenario!
david48
« Reply #5 on: November 17, 2014, 08:51:12 am »
I think Irishcarguy was trying to use slides and made a remark that the were difficult to cut . Maby a diamond wheel in the Dremmel (other multi toolbars available) . Why I say this I wanted to cut some glass from some old double glazeing which was toughend and would score with the glass diamond but would not break following the line .So I tried the diamond blade tiles saw bench with water lube fed the glass very slow and it worked Ok
David
thething84
« Reply #6 on: November 18, 2014, 10:46:22 pm »
yeh you cannot score and fracture toughened glass down a line. It is pre-cut before its toughened.
If it ain't broke! Fix it anyway!
captain bligh
  • Boats oh'd av um
« Reply #7 on: November 18, 2014, 11:37:49 pm »
Has one make a mistake by ordering microscope glass!!! Are they toughened glass if not what's wrong with a glass cutter ?
thething84
« Reply #8 on: November 19, 2014, 03:26:51 am »
i don't know if they are toughened or not. I doubt it. I was just saying to previous comment about trying to score toughened glass.
captain bligh
  • Boats oh'd av um
« Reply #9 on: November 19, 2014, 10:09:32 pm »
Yes your right once glass is toughened there is no going back to regards of cutting it ! My microscope glass hasn't arrived yet as soon as it does I'll try and cut a peice and let all know how it goes  :-))
« Reply #10 on: November 19, 2014, 10:35:03 pm »
There is nothing to beat real glass for a realistic appearance if you can get it to fit.
thething84
« Reply #11 on: November 19, 2014, 10:35:52 pm »
i would doubt microscope glass is toughened. No real need for it to be toughened. Would cost to much aswell.
irishcarguy
« Reply #12 on: November 28, 2014, 05:02:47 am »
Well the wheel never stops turning. I raised the same question a long time ago.Most said it was not possible, but Colin thought it could be done. Well been stubborn Irish I did buy slide glass on EBay & I also used the glass from photographic slides from my days doing slide shows, they were made in the USA by a company named WESS slide mounts. After a bit of trial & error I found I could cut it easy & grind the edges as well with the diamond wheel of a Dremel. How did I do it, well I carefully clamped the glass on to a piece of plywood fixed on my bench with an overhang(please wear goggles because you will break some(not as many as you would think if you are careful) Don't squeeze the clamp too tight & make sure that it is spotless clean under the glass, otherwise you will crack it( after you crack a few you will learn quick)You can with care even do curves. I was working on a rig to hold the glass better but I got very sick. I had done nearly all the windows of my Smit Nederland at that time. The breakage got less & less with practice & by taking my time. I wish I knew how to put some photos on here but that I have not mastered yet. When in place you can clean them with glass cleaner & a Q tip.Colin is right the glass looks much better than plastic. You can also glue the glass pieces together edge to edge with epoxy & it is hard to see if you need a bigger piece than the slide glass is. So have a go , you will be happy you did. Mick B.
Mick B.
thething84
« Reply #13 on: November 28, 2014, 05:14:45 am »
I have used diamond core bits to drill an aquarium I have at home which I was going to set up for dart frogs. As you say take ur time keep it wet and let the diamond do the work without any pressure on it. It cuts (wears) its way through the 6mm glass relatively quickly once its got itself started.
James
captain bligh
  • Boats oh'd av um
« Reply #14 on: November 30, 2014, 04:27:00 pm »
Hi all
Had my microscope slides come and cut them with a glass cutter no problem so result.Thanks all for your replies where would we all be with out Mayham !!!
thething84
« Reply #15 on: November 30, 2014, 09:38:31 pm »
glad it worked. post some pics of the result.
Page created in 0.06 seconds with 21 queries.
