Author Topic: Model Hovercraft Restoration  (Read 5064 times)
Hover Tim
« on: December 15, 2014, 09:15:16 pm »
Hi all
I have been asked to help with the rebuild of the model attached the woodwork is ok but the side decks are a write off and need replacing there are inflatable   and were made from what i think is canvas but something better is needed really i was thinking of using the kids inflatable toy material but would not be easy any ideas
Re: Model Hover Restoration
« Reply #1 on: December 15, 2014, 09:21:15 pm »
How about using some rip stop nylon/cheap Tent ?????/or neoprene.....just a couple of thoughts
TheLongBuild
  • Build em, and play hard..
« Reply #2 on: December 15, 2014, 09:31:34 pm »
As the man above said   %)
johno 52-11
    • lifeboat Models
« Reply #3 on: December 15, 2014, 09:34:52 pm »
Spinnaker sail cloth from a sail maker comes in all sorts of colours including black. If you can find a sail maker local to you he would probably have loads of off cuts that will do what you are looking for. The other think is it also comes in a number of different weights/thickness’s
Hover Tim
« Reply #4 on: December 15, 2014, 09:41:34 pm »
good idea lads i will bear that in mind
TheLongBuild
« Reply #5 on: December 15, 2014, 10:16:14 pm »
Where is that picture from. It rings a bell  is it at the Hovercraft Museum ?.
McGherkin
« Reply #6 on: December 15, 2014, 11:19:03 pm »
I'd love to see closeups of all those other models in the background!  O0
Klunk
« Reply #7 on: December 15, 2014, 11:44:12 pm »
Ripstop nylon is best. Get  heavy weight one though.
full time penguin
hmsantrim
rickles23
    • Royal Navy Commandos
« Reply #9 on: December 16, 2014, 06:41:12 am »
What about a model yacht sailmaker?
They usually have plenty of odds and ends.
SailorGreg
« Reply #10 on: December 16, 2014, 08:35:57 am »
....although his offcuts are liable to be a lot smaller than the full size sailmaker - many full size offcuts would make a full suit of IOM sails!
Would thick black polythene (rubble sack from a hardware store) work?
Greg
Hover Tim
Re: Model Hovercraft Restoration
« Reply #11 on: December 16, 2014, 08:35:47 pm »
I am a member of the MHA but Asked here to get a few more ideas in the pot so to speak
And yes taken at the Hovercraft Museum
sorry i dont have close ups of the models at the mo
hmsantrim
« Reply #12 on: December 16, 2014, 11:17:10 pm »
 Hi Tim.
 Did`nt know you were a member of MHA Model looks like a set of vacum bags atached to the side. Dont know is the model is static or going to be working but what about. NEOPRENE.  used for waders wellies dive suits  etc.  have a look and see.
https://www.google.co.uk/search?sourceid=navclient&ie=UTF-8&rlz=1T4GUEA_enGB581GB581&q=exogin#q=neoprene
 Frank
TheLongBuild
« Reply #13 on: December 16, 2014, 11:20:16 pm »
I have some pictures when I went a few years back, But can I find the Files !!!!  >>:-( >>:-(
Hover Tim
« Reply #14 on: December 19, 2014, 09:17:36 pm »
thanks for the help so far guys
i have attached a cut away of the full size and this is my mates idea too
My guess is that the pockets have baffles running from back to front hence the ribbed shape when inflated. For reliability  there are two options, 1) make up bags as per the original using  4 oz. Polyurethane coated polyester, which is air tight material but needs a glue sourcing or heat welding at the seams. 2) make up the deck in laminated wood as I did for the RNLI model. We have since found out they were blown up with an onboard compressor and then topped up due to the failing of air tight material available at the time we think the model had one too
Page created in 0.327 seconds with 19 queries.
