Author Topic: Bluetooth Speaker  (Read 3658 times)
Bluetooth Speaker
« on: December 18, 2014, 08:52:01 am »
I bought a Bluetooth  ( wireless )  speaker this week, very impressed!
Only cost £10 from Mr.Memory - http://www.mymemory.co.uk/Bluetooth-Speakers/Bluexen/Bluexen-Boombox-Bluetooth-Speaker---Black
Unit has an internal battery that lasted over 4 hours last night at high volume ( "high" - a few watts I guess! ).
Comes with a micro USB charge lead and a 3.5 - 3.5mm audio lead so can be used as a self contained amplifier.
About 6" long.
Re: Bluetooth Speaker
« Reply #1 on: December 19, 2014, 07:15:28 am »
 Ideal speaker / amplifier for even a modest sized boat....
« Reply #2 on: December 19, 2014, 07:35:58 am »
Good & impressively powerful sounding product code  - MB-700W ..  {-) .... Derek
Umi_Ryuzuki
    • Models and Miniatures
« Reply #3 on: December 19, 2014, 07:52:09 pm »
However,....
If you put it on your boat, and play an engine sound from your phone, it skips and hiccups.
Not bad for a horn once in a while.  ok2
http://www.amazon.com/Alpatronix-AX300-Ultra-Portable-Bluetooth-Speakerphone/dp/B0062CBCGG/ref=sr_1_1?ie=UTF8&qid=1419018787&sr=8-1&keywords=alpatronix
« Reply #4 on: December 19, 2014, 09:18:49 pm »
Umi  <*< ....this is a family friendly forum please...... "Not bad for a horn once in a while"  {-) .... Derek
Umi_Ryuzuki
« Reply #5 on: December 20, 2014, 03:54:43 am »
You must come from a land down under...
« Reply #6 on: December 20, 2014, 06:18:22 am »
 :-)) ...Umi.....from memory it was ''Men at Work"" who sang this [You must come from a land down under] when OZ first won the Americas Cup yachting race  %)
McGherkin
« Reply #7 on: December 20, 2014, 10:20:01 pm »
Bluetooth speakers are great but they do have some points to consider.
1. They work on 2.4GHz. Not too bad (certainly not as bad as the old days of 27/40MHz) until you have a lake full of models running on 2.4GHz and 20 speakers running on 2.4GHz!
2. Range is limited - Severely. 6-7M sounds a lot, but that's line of sight, and it's not exactly far away for a model, particularly a larger scale one.
3. When you lose connection, it can take forever to reconnect. And every time your model goes out of range, it will take you 10,20,30 seconds to reconnect, possibly manually.
4. Bluetooth audio streaming suffers from the issue of digital noise. Rather than go a little fuzzy, it will simply cut out, jump, and make odd noises.
None of which lend themselves very much to model boating. It's possible to use one, but it'd probably be a lot better to have the phone onboard somewhere - which kind of negates the need for bluetooth.
They are good when used 'normally' though - I can tell you from experience that a Bose Soundlink Mini will fill the entire engine room ampitheatre of HMS Scott with sound - and that really is a big achievement. That's quite an expensive speaker though, but a fairly cheap one will still perform very well so long as you stay relatively close to it.
« Reply #8 on: December 21, 2014, 01:36:02 pm »
Yes but it's also small amplifier / speaker too, with standard 3.5mm stereo jack input.
Play what you want from any MP3 player...
