Author Topic: Where to get this bit ??  (Read 5117 times)
chris gillespie
« on: January 07, 2015, 08:58:29 pm »
Hi guys
Im looking to find a stockiest for the tightening screw above the hull for rudders....please see the photo....
Just the black area, the tillers are ready available...cheers for your help
imsinking
Re: Where to get this bit ??
« Reply #1 on: January 07, 2015, 09:35:40 pm »
Doubt if you can get the body separately, plenty on EBay , various sizes . . .
 http://www.ebay.co.uk/itm/MODEL-BOAT-RUDDER-X-Large-includes-Post-and-Fittings-/201175298918?pt=UK_ToysGames_RadioControlled_JN&hash=item2ed6fb7366
Watch the pack & post costs .
Bill
jarvo
  • Etherow model boat club
« Reply #2 on: January 07, 2015, 09:42:40 pm »
HI Chris
Are you looking for the nut that tightens down on the part through the hull?  If so it is a standard thread, go to a tool stockist, the type that do machine tools.
If its the nut and bolt through the swively bit, again it is a standard item from either a model shop or the engineers supplies again.
Hope this helps
Mark
Tugs are for pulling
chris gillespie
« Reply #3 on: January 07, 2015, 09:49:08 pm »
Thanks guys
Its the nylon/hollow plastic screw and nut it has o rings and tightens around the shaft...
Cant find it advertised anywhere.... :embarrassed: :o
kinmel
« Reply #4 on: January 07, 2015, 10:23:58 pm »
The part is called the "sleeve", it is not available separately, but the whole assembly costs very little.....    http://www.cornwallmodelboats.co.uk/acatalog/boat_rudders.html
chris gillespie
« Reply #5 on: January 07, 2015, 10:37:53 pm »
I thought they might be sold separately or readily available.....as I broke one
I think its a caldercraft style rudder system, so I may contact them  :-))
As you say there not expensive, but every penny helps
Chris
« Reply #6 on: January 07, 2015, 11:25:15 pm »
why not use a piece of plastruct tubing with same inside dia as that you have....and glue it into the hull with a support block............simple little job....and being plastic self lubricating....no need for oil or Vaseline to keep free.
chris gillespie
« Reply #7 on: January 07, 2015, 11:46:32 pm »
Cheers Neil....I know it could be done with no frills its getting some plastic to fit  :police: <*<
I quite like the plastic sheath and tightening bolt,  {:-{ :((
radiojoe
« Reply #8 on: January 07, 2015, 11:49:55 pm »
Yep that's what I would do either plastic or brass tube to suit the rudder shaft, and as Neil said with a support,bonded in with epoxy, job done, plastic threads are easily damaged.
hmsantrim
« Reply #9 on: January 08, 2015, 05:41:58 am »
Hi Chris.
 I may have summit like wot you want in the spares box,  I would need to know the I/D of the hole and the tube LOA.
 Its called the rudder tube the part that you require.
 This is the coy that makes the assemblies if you want to try them first....???
 http://www.radioactivemfg.com/Catalogue/p15.htm#MA3061
Frank
chris gillespie
« Reply #10 on: January 08, 2015, 10:08:17 am »
That is brilliant Frank
Exactly what im looking for. Thanks I will give him a try.
Cheers once again
Chris
Seaspray
« Reply #11 on: January 08, 2015, 10:48:52 am »
Hi Chris
If your stuck let me know. 2 recent builds I have used brass tube in tube for the rudder assembly plus the brass rudder only. The unused parts will be about in the spares box. I have a Radio Active complete mini  rudder set old but still in bag but  the rudder was  covered with wood which has since been scrapped off so the rudder isn't nice and shiny but still has it's shape. part no I-RMA3062 R/C Rudder Mini   (EA)
In Ayr a lot or at the AMB club Sundays.
Martin
chris gillespie
« Reply #12 on: January 08, 2015, 04:36:11 pm »
Thanks for the offer Martin  :-))
Radio Active, will sell any component individually from their range ( good to know )
hmsantrim
« Reply #13 on: January 09, 2015, 04:58:14 am »
Hi Chris.
           does that mean you got a result with buying the single part required.??
 Frank
chris gillespie
« Reply #14 on: January 09, 2015, 11:12:24 am »
Hi Frank
Ive not ordered it, but the company will provide any loose item on any of their products. So they will provide the sheath, nut and o rings..for just over a pound..
They also said If I wanted a 100 of them, they would supply no problem as they make it.
Music to my ears, thanks for the link again Frank  :-))
« Reply #15 on: January 09, 2015, 02:16:17 pm »
Handy web site
Page created in 0.121 seconds with 22 queries.
