Author Topic: This also seemed like a good idea at the time.  (Read 6326 times)
Brian60
« on: February 07, 2015, 05:13:51 pm »
Have you ever bought anything on the offchance you can maybe make use of it in the future?
Well I did this last year with am Ebay bargain. Today I took them out of the packet for the first time and here's one of them, any ideas what it is?......
Re: This also seemed like a good idea at the time.
« Reply #1 on: February 07, 2015, 05:15:45 pm »
It looks like a circuit board  LED.       Did it come with a finger  ?    {-)
Brian60
« Reply #2 on: February 07, 2015, 05:16:03 pm »
Yep I bought 200 surface mount led's for 99p, thinking I could use them for deck lighting at some point. How in God's name I'm going  to solder these I have no idea! Hers' another photo of one next to a standard 3mm led.
« Reply #3 on: February 07, 2015, 05:28:02 pm »
I think you gonna need a magnifying glass.  The secret is not to put the solder iron on them, but introduce a 'tinned heated wire' to the end caps.    :}
maybe !!!
TailUK
« Reply #4 on: February 07, 2015, 05:39:29 pm »
Perhaps a low temperature solder,  I had some that worked at 70 degrees but you'll need a variable temp iron.
RAAArtyGunner
« Reply #5 on: February 07, 2015, 10:28:00 pm »
At such a bargain price you can afford a couple of failures  O0 O0  %) %) %)
Was still a good idea, done all the time.
JayDee
    • JOHN DOWD
« Reply #6 on: February 07, 2015, 10:57:26 pm »
Hello,
Clean the sides of the solder iron tip, then wrap some 1.5 mm copper wire tightly round the tip , pull the end of the wire out over the end of the tip, and use the wire to solder with.
The wire is now a very small solder iron tip !!!.
Smaller diameter wire can also be used - - with care !!.
Necessity is the mother of invention.
John.   :-))
http://www.john-dowd.
Time Bandit
« Reply #7 on: February 07, 2015, 11:06:03 pm »
Iīm just trying to describe how I solder those small LED.
I use enamelled copper wire for it, otherwise the wire is thicker than the LED. The one with the black varnish is much better since you see if itīs damaged.
To remove the varnish on the ends of the wire just heat it up with the solder iron and some tin on it.
Then I put the LED on double-faced adhesive tape and just solder the wire to them.
I use a normal temperature controlled solder iron and 0,5mm solder wire (with lead!!!).
If you can pull the LED off the tape on the wires and it doesnīt fall off, the soldering was good.
Needs some testing with a lot of not anymore working LED but now I break maybe 1% of the LED I solder.
regards
Tobias
Mad Scientist
« Reply #8 on: February 08, 2015, 12:33:04 am »
Those surface mount components were intended to be placed on circuit boards by robots, IIRC. When humans need to work with them, the humans sometimes use stereo-microscopes to see what they're doing, again IIRC.
Tom
cos918
« Reply #9 on: February 08, 2015, 08:55:00 am »
It can be done but heat will kill them . You need to be in and out quickley with the soldering Iron and cool the led stright away . I did a few and broke a far few few of them . You can buy them pre wired
john
Brian60
« Reply #11 on: February 08, 2015, 10:18:51 am »
Wow guys, some good ideas for tackling the problems there. I'll try some of them and see how I go, but to be honest ieven at 1/72 these are too small for what I intended. If I can solder any of them I may use them as indicator lights on the bridge consoles.
RAAArtyGunner
Fastfaz
« Reply #13 on: February 08, 2015, 12:17:37 pm »
  How are you going to do this? with great difficulty I should think but I'm sure you will find a way. Good luck.
       Cheers,
           Peter. :-))
« Reply #14 on: February 08, 2015, 01:30:19 pm »
Brilliant piece of lateral thinking. You learn something new all the time. :-)) :-))
Wire glue is readily available in OZ O0 O0
I have used the heating element paint to repair a damaged circuit board track on the central locking remote of my car. 2 years on its still working :)
cocktail stick, magnifying glass, a steady hand and the patience of a saint.... job done
Page created in 0.031 seconds with 18 queries.
