Author Topic: Prop pitch unknown  (Read 2581 times)
david48
Prop pitch unknown
« on: March 25, 2015, 11:40:25 pm »
Is there a easy way to work out the pitch of a prop . Brass prop 50mm dia in plastic bag no description . I know about thread pitch  ,and one revolution moves it on a given distance what ever the pitch is . If it was  a nut  on a thread no problem . For the life of me I can not come up with a method to work out the unknown  pitch.
David
Jerry C
Re: Prop pitch unknown
« Reply #1 on: March 25, 2015, 11:57:54 pm »
Measure the angle (theta)of a blade at radius r.
Pitch = 2 x 3.142 x r x tan theta. Sorry can't find Greek letters on phone.
Jerry.
boneash
  • In an actual war zone there are 2 types of ships,
« Reply #2 on: March 26, 2015, 12:08:53 am »
NFMike
« Reply #3 on: March 26, 2015, 12:36:12 am »
For a rough eyeball estimate:
1/ Put the prop on a flat surface and measure the 'height' (or 'depth') of a blade with a ruler stood on end (ie, parallel to the shaft axis).
2/ Assuming the edges of the blades are near each other (ie, if you look at the prop along the shaft line there isn't much/any gap or overlap between the closest parts of the blades) then for a 3-bladed prop multiply the result in 1 above by 3, or for a 4-blade multiply by 4.
If there is a significant gap between the blades increase the multiplier a bit, or if the blades overlap reduce it. Eg, if the blades are very narrow so the gap between the blades is about as big as the blades make the 3 a 6 or the 4 an 8. Pro-rata for other permutations.
david48
« Reply #4 on: March 26, 2015, 01:02:25 am »
Thank you all for the info will give it a go later on today ,
David
