Author Topic: Re waterslide transfers  (Read 3665 times)
Coxn John
  • Learning all the time...
« on: April 02, 2015, 12:41:26 pm »
20 + years ago you could walk into any model shop & buy waterslide transfers of letters or numbers off the shelf, in various sizes, easily.....now im finding it impossible or at extortionate prices.....or am I asking the wrong firms ?
What I need are 50mm tall waterslide transfers of black numbers, (as on the sides of Lifeboats)  any ideas where guys please ?
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: Re waterslide transfers
« Reply #1 on: April 02, 2015, 12:46:12 pm »
Coxn John
« Reply #2 on: April 02, 2015, 12:52:22 pm »
Thanks for that, i'll give it a try  :-))
Stan
« Reply #3 on: April 02, 2015, 01:03:34 pm »
HI Cox john P/M SENT.
Stan.
Coxn John
« Reply #4 on: April 02, 2015, 01:07:00 pm »
Thanks Stan, ring you after 6pm, altho I wont be at home then.
« Reply #5 on: April 02, 2015, 02:52:16 pm »
With the DIY water slide transfers, be careful with light colors on the transparent water slide paper. If the color of the surface they will be applied to is dark, the dark color shows through.
Coxn John
« Reply #6 on: April 02, 2015, 03:14:22 pm »
Thanks, but its black on orange so shouldn't be a problem
« Reply #7 on: April 02, 2015, 08:54:39 pm »
If doing black, and if you have a laser printer, you can get laser decal "paper".  If you have access to a colour laser, there is white backed laser decal "paper", but this involves a lot of very careful cutting.  I did get some dry rub laser stock, but have yet to figure it out.  Laser prints seem less liable to fade than inkjet prints, but that might be down to the ink I was using.
Coxn John
« Reply #8 on: April 02, 2015, 09:29:04 pm »
No,its a Inkjet printer
cos918
« Reply #9 on: April 02, 2015, 10:10:46 pm »
once you have done your printing you will need to seal the transfer with lacer  or varnish because inkjet ink are water soluble
john
Howard
« Reply #10 on: April 02, 2015, 10:26:43 pm »
Hi John,
Just remember which ever way you do it always put them on a glossy surface or you,ll  end up with a silvery look then finish with the look you want , gloss semi or matt.
             Regards Howard.
Coxn John
« Reply #11 on: April 02, 2015, 11:20:56 pm »
Thanks John & Howard, yes i'd already heard that.
colin t
  • Colin T
« Reply #12 on: April 03, 2015, 07:00:20 am »
For transfer paper both Inkjet and lazer try Hhttp://www.craftycomputerpaper.co.uk
I have used them a lot and they are great and cheaper than some other suppliers.  O0
