Author Topic: Our Lass Two Lights  (Read 3825 times)
Cornishman
Our Lass Two Lights
« on: April 06, 2015, 07:32:13 am »
         I am currently building Our Lass Two and am fitting working lights. However, I am a little confused with the lighting sequence.
        Starting from the top of the foremast the order is
       Single White, two greens, two reds, two whites, two reds.
       I understand the saying "Green over White, fishing at night and Red over White trawling at night" I take it that the Greens and highest Reds would be used with the Whites for this, but when are the lowest Reds used. Also is the topmost White just used when at anchor?
        Can anyone help?
Brian60
Re: Our Lass Two Lights
« Reply #1 on: April 06, 2015, 02:29:58 pm »
Check G and H in the diagram for fishing boats. Save to your desktop and enlarge with your photo viewer.
Cornishman
« Reply #2 on: April 06, 2015, 07:43:48 pm »
Thanks for the information. However, it does not show the reds below the whites, apart from the navigation lights.
Mad Scientist
« Reply #3 on: April 06, 2015, 11:49:55 pm »
Two possibilities come to mind:
Red
White
Red
for a vessel 'restricted in its ability to maneuver', for instance a warship launching or retrieving a helicopter; and
Red
Red
for a vessel 'not under command', for instance a vessel which has suffered a steering gear failure, or a main engine failure.
Neither specifically concerned with fishing. Hope this helps!
Tom
Time Bandit
« Reply #4 on: April 07, 2015, 08:37:08 pm »
Iīm not a specialist for "lighting" but isnīt "red over red" set when the nets are hauled?
regards
Tobias
Mad Scientist
« Reply #5 on: April 11, 2015, 12:41:42 am »
Yes, Tobias, you are right. That situation is described in Annex II to the Collision Regulations. It specifically refers to fishing vessels operating in close proximity.
I found an on-line resource: http://www.stormy.ca/marine/colregs/
No illustrations, but all the 'correct' terminology. :police:
Tom
« Reply #6 on: April 11, 2015, 08:52:07 am »
Two reds denote net caught on obstruction.
Mad Scientist
« Reply #7 on: April 12, 2015, 09:50:23 pm »
Oops! I managed to miss that! :embarrassed:
Tom
Page created in 1.32 seconds with 22 queries.
