Pages: 1 2 [3] 4   Go Down
Author Topic: Gopha Girl ( Springer Tug )  (Read 48638 times)
Re: Gopha Girl ( Springer Tug )
« Reply #50 on: May 14, 2015, 09:32:13 pm »
Good show Joe. I look forward to seeing her finished and on the pond, which will not be long given the speed you have been going at.
radiojoe
« Reply #51 on: May 15, 2015, 03:12:59 pm »
Thanks Ian, yes I think she'll be on the water in a week or two.  ;)
In between the various coats of paint I've still been playing around with the wheelhouse, and Sam is now permanently on board to help with the work up, as you can see Sam comes from a time before the powers that be dictated our entire lives, smoking in the work place indeed, naughty Sam.  {-) {-) {-) {-) %%
radiojoe
« Reply #52 on: May 17, 2015, 04:25:23 pm »
Finally finished the paint work, not my strong point I have to admit, had to scrape off the boot topping due to the first one reacting and crazing  %%, so redone with white acrylic which seems OK,  all that's left to do is to make up something resembling a winch for the fore deck, fit the bollards and fit the tyres around and find some sort of rubber for the rams.  :-))
« Reply #53 on: May 17, 2015, 04:39:46 pm »
After seeing the result I think mine is a bin job :embarrassed:
It has kickstarted an idea of a new superstructure.
Great job Joe !
« Reply #54 on: May 17, 2015, 06:37:51 pm »
Ok, so she isn't a Rembrandt. But she has been well finished and you made the effort to re do the Boot topping, so you can't say you bodged it.
I saw on a friend's Military Trawler that the winch looked like it had been made from a set of G gauge railway wheels (for the sides of the drum) and other gizmology, so if you know of a friendly model railway shop that sells stuff like that, they may have a pair of wheels you can use?
Big Ada
« Reply #55 on: May 18, 2015, 04:47:34 pm »
Rubber for the Rams = a section from an old Timing Belt,  ask at your local Garage for one.
Len.
radiojoe
« Reply #56 on: May 18, 2015, 05:03:37 pm »
Thanks Ian I think I've managed to cobble some bits together. :-))
Thanks Len that would be perfect I'll see what I can scrounge. :-))
Here's what I've made so far, the large gear is an old drive sprocket out of a RC car, I'll paint some of it before assembly, I'm attempting to make it work, I've no idea why  %% %%
« Reply #57 on: May 18, 2015, 08:18:46 pm »
You are pining for a complex job to solder and this is a good substitute:O)
Looking good Mr Radio.
radiojoe
« Reply #58 on: May 19, 2015, 05:36:17 pm »
Well I finished the winch and it works just got to wind some "cable" on the drum, truth be told it's probably a bit over scale but Springers are supposed to be fun so I'm not too bothered about it,  Sam's a little guy and this is a BIG winch. %% {-) {-) {-)
« Reply #59 on: May 19, 2015, 08:36:47 pm »
It looks like it would work!
radiojoe
« Reply #60 on: May 21, 2015, 03:42:44 pm »
Just about finished now, I made a oil drum and cast some off to add a bit of interest to the fore deck, fitted the fender tyres, still need to get the rubber for the rams, she has been great fun to build, it made a change to build from imagination next we'll see how she performs on the lake. %%
Bob K
  • Bob K
« Reply #61 on: May 21, 2015, 04:09:31 pm »
Love the working winch, and oil drums.  When working to your imagination the 'rivet counters' can take a running jump  {-)
« Reply #62 on: May 21, 2015, 04:34:01 pm »
Lovely job there Joe.
Even a handraulic bilge pump :-))
I think mine has to have a makeover
From the deck up.
newbe7
« Reply #63 on: May 21, 2015, 07:26:14 pm »
As a new member I'm reading as many posts for information as I can, what a great build.
Rick
« Reply #64 on: May 22, 2015, 12:03:39 am »
She is very attractive Joe. One to put on the build list I reckon. You must have a good selecetion of moulds now?
Big Ada
« Reply #65 on: May 22, 2015, 05:48:05 pm »
I guess your Moulds are flexible? where do you get your supplies from?.
We could do with a Master Class on making Moulds and casting.
radiojoe
« Reply #66 on: May 22, 2015, 07:40:33 pm »
Yes the moulds are made from flexible silicone rubber, I get the silicone and resin from www.easycomposites.co.uk ok it's not cheap but it goes a long way, and I find it a fascinating extension to our hobby, I'm certainly not a master at it but it's really quite easy, just take some time making the fitting, fittings with a base such as bollard are the easiest, bond the fitting into a "box", I make the box out of styrene,  mix the silicone and fill the box being careful to avoid air bubbles, when cured remove the sides of the box and remove the mould, depending on the fitting you can just flex the mould off others you need to cut the mould in half, it will then fit together and held with elastic band, mix the resin and fill the mould again avoiding air bubbles, that's it make as many as you want.
bat44
« Reply #67 on: May 22, 2015, 09:48:44 pm »
Nice to know there is more then one springer in town
radiojoe
« Reply #68 on: May 22, 2015, 10:57:15 pm »
I do like the weathering on that Springer, very nicely done.  :-))
radiojoe
« Reply #69 on: May 24, 2015, 05:17:32 pm »
Gopha Girl had her first trials today, have to say very pleased with it, the handling and performance exceeded my expectations, more than enough power which will be useful when pushing and the fishtail rudder really dose the job, hard over she pivots on the spot, a good speed before the tendency to dip the bow, I did make the mistake of ballast trimming before I decided to add the winch and fore deck detail so this was enough to lose the slightly bow up attitude, so now have removed some ballast, when I got home I noticed she had shipped a small amount of water I suspect the prop tube, I've never liked the greased one that much but I used it as I had it spare, with hind sight I think it would have been worth the expense of a water proof one, it took some more grease though the grease tube so maybe I didn't have enough in it, I've just sectioned off the area beneath the inboard end to form a coffer dam to contain any more drips, all in all she's a lot of fun to sail :-))
« Reply #70 on: May 25, 2015, 11:18:34 am »
Very nice build.  Glad you enjoyed its sailing.
Yes, they are fun and also make excellent rescue boats.   :-))
« Reply #71 on: May 26, 2015, 11:29:06 am »
Lovely work chaps! That weathering would make a military modeller proud!
I am glad that even with a simpler model you have found some things to teach us Joe. I will keep the coffer dam idea for future projects, though probably making sure your tubes etc are water tight/secure is more important.
plug
« Reply #72 on: May 27, 2015, 04:11:33 pm »
That's a cracking little springer radiojoe . like the ratchet on the winch
regards Jack.
radiojoe
« Reply #73 on: May 28, 2015, 04:44:51 pm »
Thanks to all for your interest and comments,
Went on her second trials today again nearly two hours in the water and this time dry inside the first time must have been lack of grease in prop shaft, so I think now I'll take her every time, reassuring to know there's a back up. :-))
Thanks for watching. :-))
radiojoe
« Reply #74 on: January 08, 2016, 03:02:48 pm »
Just an update on fitting my spare 12 volt smoke generator, when I built her I thought that I may fit one at some point so made provisions in the exhausts etc. so it was just a case of making a chamber under the two stacks and fit the smoker in the right place and wire into the ESC, there is a bit too much smoke indoors but with forward movement and a bit of a breeze I hoping it will look more realistic.
Pages: 1 2 [3] 4   Go Up
Page created in 0.033 seconds with 22 queries.
