I was asked to fix a leaking lifeboat rib for Garreth, one of my build clients, this has turned into a full refit/rebuild. The original is a Models by Design 1/10th scale Atlantic 21 style rib ( why they moulded it at 1/10th and not 1/12th scale is beyond me!). The client wanted it to look more like an Atlantic 85 as well as the leaks fixing thus this rebuild.
The hull is a couple of inches too long for a true scale A85 so it will be a 'stand off scale' model.
State of the boat when it arrived.
The leaking problem was that the ply transom plate had a couple of cracks in the epoxy where it was attatched to the moulding.
The plate was removed and the inside of the moulding was sealed with epoxy to fill all the existing holes.
A pattern for a new birch ply transom was made and cut out.
This was fitted onto the moulding with epoxy and allowed to set for 48 hours before the clamps were removed.
The underside of the hull and transom were then rubbed down and given a coat of primer.
