Author Topic: Where to buy Tissue and Dope  (Read 7077 times)
Kadtoy
« on: June 08, 2015, 11:18:18 am »
Fellow model builders,
Where is the best to buy Tissue and Dope.
I decided to build a Springer and have just about completed the hull, and now need to get some dope and tissue.
I must get some pics of the progress to post up here. First boat to be scratch built and really happy with it.
David
Re: Where to buy Tissue and Dope
« Reply #1 on: June 08, 2015, 11:44:19 am »
Your best bet would be a local model shop if you have one. Otherwise Google Cellulose Dope and pick a supplier.
JB
  • Resting in Drydock.
« Reply #2 on: June 08, 2015, 11:54:00 am »
Try Inwood models for tissue and dope,
http://www.inwoodmodels.com/index.php?
Best to phone them I think.
XJ6 - Powered by Jaguar   JB - Powered by Model Boat Mayhem - Currently On sabattical (forced-unpaid!)
Kadtoy
« Reply #3 on: June 08, 2015, 11:55:16 am »
Thanks so much, I will give them a try...  :-)
Arrow5
« Reply #4 on: June 08, 2015, 12:53:24 pm »
As a matter of interest, what are you going dope and tissue ?   The hull of these little beasties tend to get some abuse, tissue and dope might not be tough enough.  OK for the topsides though.  Brown wrapping paper and waterproof PVA is a cheaper, stronger alternative. Best of all of course is fibreglass and resin from Halfords, messy, smelly, overkill perhaps.  Is your hull made of balsa ?
..well can you land on this?
Kadtoy
« Reply #5 on: June 08, 2015, 12:57:23 pm »
Yes I was looking at the hull to dope and paper, But I also have fine fiberglass tissue and resin if need be.
Would you suggest glass and resin on the hull?
David
Arrow5
« Reply #6 on: June 08, 2015, 01:01:04 pm »
Yes glass it if SWMBO will let you. Is it a hardwood hull ie not balsa?
Kadtoy
« Reply #7 on: June 08, 2015, 01:13:50 pm »
Cool, thanks for the advice, Much appreciated.
Arrow5
« Reply #8 on: June 08, 2015, 01:23:28 pm »
Glad to help....now you owe us some pictures...it is a Springer Rule  O0 {-)
Kadtoy
« Reply #9 on: June 08, 2015, 01:28:53 pm »
Will get some pics up in the very near future. :-)
« Reply #10 on: June 08, 2015, 01:41:17 pm »
Pedant mode on "technically Balsa is a hardwood" pedant mode off  :-))
Kadtoy
« Reply #11 on: June 08, 2015, 02:12:05 pm »
So this is where it all started, one day sitting at lunch thinking what can I do.
Lets draw a Springer Tug, Got the hull Dimensions off the net and started to play
Arrow5
« Reply #12 on: June 08, 2015, 04:59:08 pm »
  So that is why most my model aeroplanes fly like bricks  :embarrassed:        Good start Kadtoy but rear deck will be needed, rudder and servo.
john44
« Reply #13 on: June 08, 2015, 06:53:46 pm »
Also freeing ports/scuppers to take the water on the rear deck away, because there will be some. {-)
Kadtoy
« Reply #14 on: June 08, 2015, 07:16:45 pm »
Thanks guys. I was so keen to get a pic up that I forgot to put the hatch and water uprights on the model.
But saying that I may change the design as I was drawing a scaled Hiab that I may have to make and put on it.
Purely asthetic.
Kadtoy
« Reply #15 on: June 25, 2015, 01:46:28 pm »
It's starting to take shape, slow but sure.
« Reply #16 on: June 25, 2015, 02:05:40 pm »
All you need to do is to go down to halfords and buy some clear laquer......spray on a couple of coats  rub it down with 240 grit DRY DRY DRY not wet couple more ...do the same and then simply use primer filler ....rud down DRY and NOT wet ....spray on primer and then colour of your choice ....seriously there is NO need at all to tissue and dope it or fiberglassing it
Kadtoy
« Reply #17 on: June 25, 2015, 02:09:28 pm »
Cheers for the information Dave, I hadn't thought of using that as a sealer, very nice idea.
Thanks so much.
Page created in 0.016 seconds with 22 queries.
