Guys.....as an apprentice...each year one of my jobs during the 3 week shut down of the copper & brass tube mill was to ride the 300 foot long enclosed continuous inert gas charged, induction electrically heated tube annealing furnace
...[these tubes were destined for domestic water]
The gas was to ensure the tubing remained a mirror bright, without any form of internal or external surface oxidation, last 20 foot was a natural cool down segment...before reaching the open atmosphere
With respect to heating and water quenching, this is done to achieve a dual physical metal matrix....an example here is the manufacture of shell casings....yes for large ordnance.......the casings are punched from annealed brass which is horrendously work hardened during that process, then the interface of the casing where the projectile is mated is the reannealed and water quenched
The purpose of this is to maintain the high mechanical strength and rigidity of the casing, with the exception the annular band are where the projectile is swaged
From a metallurgical point, you certainly can heat then water quench brass tubing to create an annealed state, however the intergranular metal structure is a far more defined by position, & hence for our purposes I choose to anneal slowly.....this then provides a longer transition band between the planned area to be bent
Water quenching of 1 ft long lengths of our model tube also has an influence in causing buckling of the lengths, which then also needs to be rerolled on the teflon kitchen chopping board...which does not impress your spouse
Without the luxury of a 7000 kW induction heater in the kitchen, I use canister gas for the heating and yes this does cause oxidation blackening, however a simple polishing with a non abrasive liquid removes this and provides a smoother surface for the Teflon body of the bender to slide over....prior to the reapplication of the TEXTA colour marks
Naturally if Ken would transfer a few postings to this thread would be appreciated
.................Derek
Thank you Derek. The relevant postings have been brought over to this thread.
ken
