Author Topic: recommend a soldering iron  (Read 5926 times)
Mike0001
« on: July 20, 2015, 09:32:44 pm »
bought one of these kits with the de soldering pump, iron stand etc for originally restoring my late dads cb550, went to use it today for second time and its dead as a dodo... of course just passed the warranty period
so now looking to buy  reasonable price stand alone soldering iron ( no fancy accessories ) and thought about this one
http://www.ebay.co.uk/itm/58W-Variable-Temperature-Soldering-Station-Iron-Electronic-W-Extra-Tips-312095-/291515322349?pt=LH_DefaultDomain_3&hash=item43dfaacfed
just for my dads motorbike wiring and use on my model boats to so will be reasonably light use
let me know what you guys use or recommend if you know better
thanks
Re: recommend a soldering iron
« Reply #1 on: July 20, 2015, 10:10:08 pm »
Looks great for the price!
 Can you get spare tips, element?
Fastfaz
« Reply #2 on: July 21, 2015, 05:20:38 am »
Have you looked at the "Component shop" kits?
    Cheers, Faz.
sparkey
« Reply #3 on: July 21, 2015, 07:49:19 am »
 :-)) Weller soldering are the best you can buy,bought a second hand 24v one with transformer 35 years ago from a school that was closing down for a fiver,still going strong and you can still get tips and spares! also got a 230v one which is exactly the same design,these irons are not cheap but are well worth it,Ray :-))
inertia
« Reply #4 on: July 21, 2015, 08:39:51 am »
I use a Weller, too, but they are eye-wateringly expensive. Antex has always been a good budget choice - British made so no problem with spares, tips, elements etc. This one is the 25W mains version with silicon cable, which is much easier to handle than the version with PVC cable. You can also find it with a coil-spring stand and sponge wipe. Recommended. http://www.amazon.co.uk/Antex-Xs25w-Soldering-Silicone-Cable/dp/B005ZEM7YI/ref=sr_1_1/280-2049977-0625622?ie=UTF8&qid=1437464181&sr=8-1&keywords=antex+soldering+iron+25w
Dave M
« Reply #5 on: July 21, 2015, 09:07:33 am »
While I have a selection of electric irons of various sizes going back into the mists of time (Weller, Antex, something huge with no name), most of my soldering these days gets done with an Idodo gas iron.  No trailing lead, just needs care about the exhaust gas.
GAZOU
« Reply #6 on: July 21, 2015, 09:13:28 am »
I use ONE WEBER with stabilized temperature.
To use a sponge creates a thermal shock and abime the breakdown.
Use a straw block of brass, clean in every weld the end of the iron by plunging the iron into the paiile
« Reply #7 on: July 21, 2015, 04:19:20 pm »
Watch out for dodgy sellers on eBay.
You might get your fingers burned  {:-{
Mike0001
« Reply #8 on: July 21, 2015, 08:01:11 pm »
I bought one of these so called great all in kits last year for 12 pounds
every thing worked
"once "
maybe looking at the weller ones. more expensive but you get what you pay for
spearfish99
« Reply #9 on: July 21, 2015, 11:09:15 pm »
Still using my Weller 80W soldering gun that I bought some 35years ago. Still get replacement tips for it. Great for wiring electric boats
inertia
« Reply #10 on: July 22, 2015, 08:43:53 am »
This is the one I've used for the last seven years. Don't say you weren't warned about the price, though! http://www.ebay.co.uk/itm/Weller-WS-81-Soldering-Station-Analog-80W-230V-/121439103209?pt=LH_DefaultDomain_3&hash=item1c4655a8e9
DM
Brian60
« Reply #11 on: July 22, 2015, 10:59:12 am »
The Ebay one by the OP, it looks similar to a chinese 25watt one I have (yes I know its variable) If it is I would steer clear. After being on for 10-15minutes the handle is so hot it cannot be held in the hand without burning the skin. I have a Draper 35watt one that can be left on for an hour and the handle is nowhere near the temperature of the chinese one.
GAZOU
« Reply #12 on: July 22, 2015, 11:17:26 am »
To buy cheap is too dear for me, I have enough currency to buy cheap
sparkey
« Reply #13 on: July 22, 2015, 11:26:16 am »
 :-)) To add to my earlier post on this subject there are some good gas irons out there,these can be taken to the lake for the odd job and the mini torch is very handy(I use mine for soldering bullet connectors and heat shrink) but does not have the temperature control of a good mains iron,so you have a wide choice of options and like everything in this world you only get what you pay for,Ray. :-))
Mike0001
« Reply #14 on: July 22, 2015, 11:33:20 am »
well decided on a weller one, but a bit more modest version, may upgrade or add at later date
we should have a section on here for rating tools to build boats, some great advice and tips here
thanks for all your help and advice
sparkey
« Reply #15 on: July 22, 2015, 11:44:18 am »
 :} Hi,Mike,I think you have made a good choice even the basic Weller models are great and will give many years of service,let us know how you get on with it, and if you have any photo's of your builds as I like most of the crew on here love to see other peoples models,Ray. :}
