Author Topic: Charging batteries in situ  (Read 2308 times)
andyram
  • Derby M.B.C. Celebrating 40 years afloat 1976-2016
« on: August 12, 2015, 12:46:37 am »
Planning the layout of my next project,Our Lass II.I would like to leave the two 12v 7amp batteries in situ.Looking for suggestions please for a neat way of  making an on board charging station.Advice,suggestions ,pictures very welcome.
Thanks,
Will.
david48
Re: Charging batteries in situ
« Reply #1 on: August 12, 2015, 12:57:41 am »
Have you had a look at the wireing diagrams on Componat shops there could be something , I have a drawing kindle done by Inertia /DM  for my Fairmount ,I could copy it for you but it would have to be the post as I only work the IPad, there will be an electronic way but sorry I can not do it ,if all else fails PM me David
inertia
« Reply #2 on: August 12, 2015, 08:15:32 am »
http://www.action-electronics.co.uk/wd.php
Scroll down to On-Board Charging
DM
inertia
« Reply #3 on: August 12, 2015, 08:54:52 am »
Here's another version:
roycv
« Reply #4 on: August 12, 2015, 09:14:46 am »
Hi I have a couple of boats where I have connected the charging connections for the battery to 2 separate brass bollards, otherwise unmarked.  The bollard on the port side is red so must be positive.
Simple thinking, a double pole change over switch which is also the on / off switch when in the off position goes to the bollards.
Hope this helps,
regards Roy
spooksgone
« Reply #5 on: August 12, 2015, 11:53:53 am »
HI. I used a p103 parallel power board from Action Electronics for the same setup as yours. Just remember to have a charging socket for each battery. It all works really well. I will try to get some pics tonight if I can for you. Phil
Page created in 0.657 seconds with 21 queries.
