Author Topic: Trying to find  (Read 2861 times)
Trying to find
« on: September 06, 2015, 03:10:44 pm »
Trying to find a UK stockist for this:-
The part number is RO1445 and while many shops advertise it none actually have any in stock.
The same seems to be the case in Europe as well. Or if they do stock it the postage is prohibitively expensive.
Suggestions for an alternative would be welcomed although the dimensions must be the same or very close.
If someone has one lurking in their bits box that too would be welcomed. (I don't need the insert sleeve bit)
Perkasaman2
Re: Trying to find
« Reply #1 on: September 06, 2015, 04:20:41 pm »
Cornwell Model Boats have something that looks similar:
http://www.cornwallmodelboats.co.uk/acatalog/radioactive-heavy-duty-couplings.html
Leaky Bottom
Re: Trying to find
« Reply #2 on: September 06, 2015, 04:57:18 pm »
Umi_Ryuzuki
    • Models and Miniatures
Re: Trying to find
« Reply #3 on: September 06, 2015, 05:34:33 pm »
Re: Trying to find
« Reply #4 on: September 06, 2015, 05:57:22 pm »
This company seems to have them in stock http://www.krickshop.de/Elastik-Schiffsmodell-Kupplung.htm?shop=krick_e&SessionId=&a=article&ProdNr=ro1445
Yes I know, and they want 19.95 euros postage  :((
There are a few in Europe with them in stock but all of them want silly amounts for postage.
Perkassaman
The Radioactive ones are almost twice as long and will not fit where I want to put them. Hence why I said the same dimensions (28mm long)
Umi Ryzuki
Thanks for the suggestion, but again these are too long
Although I am now thinking perhaps I can use the inserts from the universal couplings and fit my own bit of rubber pipe
Does anyone know the diameter of the fluted section of these inserts
Perkasaman2
Re: Trying to find
« Reply #5 on: September 06, 2015, 06:08:37 pm »
MMB - Marks Model Bits used to sell them with his 900 motors. He supplied the tubing long so it could to trimmed to length. It might be worth an enquiry he is very helpful and will know sizes at least.
http://marksmodelbits.ieasysite.com/
Re: Trying to find
« Reply #6 on: September 06, 2015, 06:28:19 pm »
hi there essex2visuvesi
the outside diameter of the flutes is near enough 8mm - or if you want to be spot on - 2 of them out of 5 are 7.9 mm and the other 3 are 8 mm.
Also, do you have a car auto shop where you live? If you do, call in there because you may be able to purchase re-enforced flexible fuel piping.  You can cut the pipe yourself to the required length and use brass inserts.
http://www.ebay.co.uk/itm/Nitrile-Rubber-Smooth-Fuel-Tube-Petrol-Diesel-Oil-Line-Hose-Pipe-Tubing-Breather-/130740225601?var=&hash=item1e70b98641
aye
john
barriew
Re: Trying to find
« Reply #7 on: September 06, 2015, 06:46:58 pm »
Mobile Marine Models also sell ones like MMB. Again, you can cut the tube to whatever length suits.
Barrie
Re: Trying to find
« Reply #8 on: September 06, 2015, 09:44:57 pm »
Thanks for all the suggestions chaps :)
Going to order some inserts and grab a bit of fuel line from the workshop
