Author Topic: Graupner 'Fuchs' - scale fittings question  (Read 2794 times)
ddraigmor
« on: July 26, 2007, 08:07:51 pm »
Hi all,
Have just bought a Graupner 'Fuchs' off e-bay for £20 - no motor, rudder, prop or shaft and a few small bits missing but otherwise OK.
What scale would be the best to use? The kit says it is a 1/40th, but I cannot find fittings for it at that scale! I am looking for a Danforth type anchor, vertical bitts, towing bitts (double cruciform type) cleats (which are called fairleads but trust me, as an ex tugman, fairleads are totally different!), vents, radar scanner and nav light boards, winch (towing or general purpose) crane and last of all - what motor and shaft size plus prop would be useful and could I fit a steerable kort?
Any help would be most gratefully received. PS - I am an absolute novice so treat me like the average idiot!
Thanks - Jonty
colin-stevens
Re: Graupner 'Fuchs' - scale fittings question
« Reply #1 on: July 26, 2007, 09:06:12 pm »
have alook at the Graupner site. failing that get in touch with Westbourne models.
colin
grumpy old XXX
« Reply #2 on: July 26, 2007, 09:45:10 pm »
Graupner and Robbe both do 1:40 scale.
Westbournes do a large range of fittings, give them a ring. 01202 763480
Web site:  http://www.westbourne-models.com/#1X0
ddraigmor
« Reply #3 on: July 27, 2007, 03:05:47 pm »
Thanks lads - got a good hit from Cornwall models, and will give them a try and see what they come up with.
Any hints on how to paint the glass (plastic really) see through wheelhouse?
Jonty
« Reply #4 on: July 27, 2007, 03:36:52 pm »
Rub down with a fine wet and dry paper and paint. The last one I did was the Robbe PT 15 and I masked the windows and sprayed with Plasticote primer.
Remember to cover the insides of the windows to prevent over spraying. Bluebird also did it on his build.
http://www.modelboatmayhem.co.uk/forum/index.php?topic=4447.0
ddraigmor
« Reply #5 on: July 28, 2007, 01:03:06 am »
Thanks DickyD,
I'm still working on an ex RTR Dickie / Hen Long 'Workboat' which I have savaged and added to, and she's a good way from being finished. At the moment I might static her buit who knows...? Once that is done, I plan to make a start on the 'Fuchs' but am loking at major mods to make her appear better.........
Darn this model boat lark - it's infectious!
Jonty
Ghost in the shell
« Reply #6 on: August 21, 2007, 06:18:12 pm »
to give a more scale appearance, you could plate over the super structure with ABS, having cut out the window frames and sprayed first, that way your windows will look set-back rather than flush.
Go Nuclear!  you'll love it
ddraigmor
« Reply #7 on: August 22, 2007, 01:51:47 pm »
Ghost,
She's still in the box at the moment - winter project maybe! House painting / son visting / sis in law visiting (3 weeks course at Brize Norton...) and work first!
Oh the pains of reality........
Jonty
Page created in 0.097 seconds with 21 queries.
