Author Topic: Need to change my battery  (Read 2796 times)
timbo
« on: September 27, 2015, 09:05:35 pm »
I need to change the battery on my puffer
At the moment it has a rechargeable VRLH 12v  3.0 AH/20hr with a MFA Torpedo 500 4.5 -15v Dc motor with a 6.1 gear box.
15 Amp Mtroniks speed control
45 mm prop
The question is what would be the best replacement as the old one is not holding its charge any more.
Tim
Re: Need to change my battery
« Reply #1 on: September 27, 2015, 09:32:09 pm »
Probably another of the same dimensions and weight.  No battery lasts forever, and we tend to not treat ours very well.
« Reply #2 on: September 27, 2015, 09:34:09 pm »
You need to ensure that the  Amp Hours are as large as you can afford, if you want to extend your run time.
I'm confused over the exact value of the one you have.
« Reply #3 on: September 28, 2015, 07:45:16 am »
12 volts, 3A/H, in this case at a low rate over 20 hours.  If it was a lithium battery it would be labelled as 0.05C.  Habitually drawing at a higher rate (which we all do) will shorten its life (which happens to all of us).
timbo
« Reply #4 on: September 28, 2015, 07:46:40 am »
So am I  {:-{
Its a sealed lead acid
The details on the side are 12v 3.0 AH could I change to NiMH or NiCd of a lower voltage ⚡
« Reply #5 on: September 28, 2015, 08:13:20 am »
Yes, but the lower voltage will give reduced performance.  Put enough NiMH cells in series and you get 12 volts (i.e. 2 of 5 cell packs, both of the same A/H rating).
timbo
« Reply #6 on: September 28, 2015, 08:15:32 am »
Thanks will give components a call today and get some ordered
Page created in 0.014 seconds with 22 queries.
