Author Topic: huntsman  (Read 2036 times)
MadMax
huntsman
« on: October 09, 2015, 09:08:37 pm »
hi all
      sombody on this forum will know this........35 inch huntsman ....what brushless set up do i need to
      make it go like the wind....motor....esc......prop
                                             would be gratefull for info
canabus
Re: huntsman
« Reply #1 on: October 10, 2015, 11:37:13 am »
HI MadMax
Hobbyking.
Motor 3648-1450kv
ESC car HK-100A with reverse(programme card required)
Battery Zippy Compact 5800mah 4S 60C ( good charger required)(about 1/2 an hour per battery).
Battery alarm( the black case ones are better).
Prop 40mm x 1.4 pitch alloy.
These motors like to rev so over prop-ing slows the boat, loads the motor and ESC, also cuts your run time.
A Turnigy Watt Meter is very helpful when testing other props, etc.(code TR-WATTMETER).
Order connectors( I like the XT-60 ones) less problems with shorting out and you cannot reverse them.
Motor and ESC require NO cooling, so, no plumbing!!!
Re: huntsman
« Reply #2 on: October 10, 2015, 12:22:03 pm »
Here's my setup
http://www.modelboatmayhem.co.uk/forum/index.php/topic,36813.0.html
enough power to stand it on the transom if you are heave handed with the throttle  O0
