Author Topic: Limit Throw of a servo  (Read 3312 times)
me3
« on: October 20, 2015, 08:00:39 pm »
Hello There,
I need to limit the throw of a servo to around 45 degrees. I do not have room for a P96 and have a Planet T5. Is there anything else on the market I can do this with?
Re: Limit Throw of a servo
« Reply #1 on: October 20, 2015, 08:07:46 pm »
Would shortening the servo arm have the same effect.  ?  You would get less throw that way.
me3
« Reply #2 on: October 20, 2015, 08:35:19 pm »
Unfortanly I am mounting the servo vertically and using a shaft for a throttle so there is no arm  <:( Thanks Anyway
« Reply #3 on: October 20, 2015, 10:41:02 pm »
Does the T5 have End Point Adjustment (EPA)?
*edit*
Seems not according to the manual
This should work tho:-
http://modelradioworkshop.co.uk/shop/servo-control-devices/servo-end-point-adjuster/
mrturbo553
    • North Sea winches
« Reply #4 on: October 20, 2015, 10:51:49 pm »
Is one of these any help , you look to be able to shorten as well as stretching .
http://www.ebay.co.uk/itm/231720647105?ul_noapp=true
Aid
Gone racing back in 9.5 sec
http://www.nswinches.co.uk
« Reply #5 on: October 20, 2015, 10:53:57 pm »
NO end point adj on the Planet T5
« Reply #6 on: October 20, 2015, 11:06:43 pm »
Aid
Thats what I just linked to :)
« Reply #7 on: October 21, 2015, 04:38:03 am »
« Reply #8 on: October 21, 2015, 07:18:04 am »
Why not limit the throw of the throttle stick with a slotted disk?
me3
« Reply #9 on: October 21, 2015, 07:27:44 am »
Thanks for the suggestions chaps!  I will have a look at the links! It's for a throttle on an engine so could do with full throw on the radio, unfortunately the Action P96 is too big to go in my radio box which is ashame!  >:-o
JimG
« Reply #10 on: October 21, 2015, 09:59:57 am »
A rather more expensive solution is to use a Hitec digital servo and the Hitec servo programmer. This allows you to set the throw in the servo itself and doesn't need any external electronics.
Jim
Dundee Model Boat club
inertia
« Reply #11 on: October 21, 2015, 10:20:09 am »
You might contrive a linkage like this if you can't reduce the throw at the servo disc:
Page created in 0.026 seconds with 22 queries.
