Author Topic: Fitting Billings Boat stantions  (Read 3393 times)
Captain Anonymous
« on: July 31, 2007, 09:42:16 am »
Billings Boat stantions are a little bit more expensive but are well worth the extra money.
I mark out the position of the stantions and drill the holes, glue each one in position making sure the holes are running correctly ,I pass a very small drill though the hole and line it up with the flow of the rail.
glue in all the rails and leave to set.
Captain Anonymous
Re: Fitting Billings Boat stantions
« Reply #1 on: July 31, 2007, 09:50:25 am »
I use flight cable for the wire, it passes through the holes quite nicely.
Captain Anonymous
« Reply #2 on: July 31, 2007, 09:52:44 am »
Same at the stern. Again glued in with super glue.
gary r uk
« Reply #3 on: July 31, 2007, 11:57:16 am »
hi captain
that looks very us destroyer like perhaps a moffet
secrets safe
gary
SAILING WITHOUT FAST ELECTRICS PRICELESS
wingertaz
« Reply #4 on: October 24, 2007, 04:50:05 pm »
Flight trace wire can also be obtained from fishing tackle shops in different thickness's. Be carefull though of the trace wire which is covered in PTFE ! This type can only be super glued.
Regards Gary
Page created in 0.172 seconds with 21 queries.
